Author Topic: Pilot Screw Adjusting Tool  (Read 743 times)
Offline Borth42
« on: August 27, 2019, 09:13:56 AM »
I just want to get some feedback if possible.
Will this tool do the trick for adjusting the Pilot Screw on a 1979 CB650?
Motion Pro 08-0119 Pilot Screw Adjusting Tool
https://smile.amazon.com/gp/product/B000UKD6YC/ref=ox_sc_act_title_2?smid=A2F5NN4BGKFD8K&psc=1
Thank you!
Offline DaveBarbier
« Reply #1 on: August 27, 2019, 03:39:30 PM »
I assume you’re taking about the idle mixture screw and not unscrewung the pilot jet. I don’t know for sure, but I would say yes. Although any small short flat head would work. I made a little crap one that I used for mine. I know the PD carbs and they aren’t that easy to get to but on a cold motor a small screw driver works fine.
Offline Borth42
Re: Pilot Screw Adjusting Tool
« Reply #2 on: August 30, 2019, 07:32:51 AM »
Thank you.
My hands are all burned up from adjusting once the bike is at operating temperature.
And yes, not pilot jets, to adjust the a/f mix.
« Reply #3 on: August 30, 2019, 10:15:15 AM »
Thank you.
It adjusts the idle A/F mix ratio.  Need a right angle screwdriver.  I made one from a slot car rear axle pinion gear.
