Author Topic: 550 K1 start button issue  (Read 684 times)
Offline Erny
« on: August 30, 2019, 03:11:03 PM »
Aftet last wash I found start button broke off...
Is there any possibility to buy one ( 3D printed)? Of should I try to fix by JB weld?
Seeing contact inside it might not be very straightforward...
Sorry for asking help before trying to open & fix...
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Re: 550 K1 start button issue
« Reply #1 on: August 31, 2019, 12:04:20 AM »
You need to look inside and see which starter button you have, one type simply grounds to the bars(1wire) and was available seperate the other switches power from headlight to starter(3 wires) and only comes with the complete switch
Offline Erny
« Reply #2 on: August 31, 2019, 12:11:30 AM »
I have swich combined with headlights, see attached. Now fixed temporarily with tyre rap and piece of rubber to avoid it will fall apart while riding..
I remember there was some thread where somebody offered 3D printed spares... But not sure if on this forum and if for 550...
« Reply #3 on: August 31, 2019, 01:00:26 AM »
It was this forum and for a 400 but same.
 The 500 has the light switch the same its internaly the switch varies. Looking at that light switch you might have the early type start button, all you have to do is undo the screws and look in the bottom half to find out!
« Last Edit: August 31, 2019, 01:02:35 AM by bryanj »
Offline Erny
« Reply #4 on: November 05, 2019, 02:57:01 PM »
Refreshing this thread
Finally found time to disassemble right swith, here are pics of the starting button.
So question remains the same - is there any possibility to buy spare button only or I need to look for the whole switch?
Offline Erny
« Reply #6 on: November 05, 2019, 03:20:59 PM »
Wau!!! so easy!  ::)
thanks!   :D
Offline Erny
« Reply #8 on: November 06, 2019, 07:42:12 AM »
Yes, it looks Honda part 35317-001-310 is the one I need, but they do not mention anywhere compatibility with CB550K1 switch.
But on the picture it looks the same, so I'll risk it and buy it ;)
Thanks to all!
