Author Topic: '73 cb350f siezed barn find!  (Read 22644 times)
Offline 574hondarider
« on: September 03, 2019, 05:37:29 AM »
Found this original owner bike in a barn over the weekend.  17000 miles.  Original owner (widowed), has been sitting since the early 80s.  100 percent there and never been molested (doesn't even look like carbs have ever been opened.  Engine is siezed.  This is my first attempt at bringing a bike back to life (the other 350f I got early this year was already running decently).
I removed the plugs and shot a squirt of wd40 and let is sit a few hours, then tried to gently rock the bike in gear.  Then, shot a little pb blaster down there and let it sit overnight, still not budging.  Next step....top cover removal??
Electrical seams to work besides bad battery and bad turn signal relay.  Some surface rust inside tank, clutch goes through gears.  Triple top clamp has 2 cracks.  Looks like it may have had a leaky head gasket.  Front brake not working.
My thoughts to bring this back to life.....
1.  pull carbs and soda blast and get new o rings/kit and reassemble
2.  use some product to get rust out of tank and go through petcock.
3.  take top cover off and attempt to get pistons free.  While doing so, maybe remove the top end assembly and soda blast, then replace gaskets.
4.  buy new triple top off ebay.
5.  master cylinder brake kit?
6.  new tires
Does this sound like a proper course of action?  I am openn to any suggestions as I am new to all this but thought this would be a good winter project.  Also debating about taking it down to the frame for a proper restore.  BTW, paid $700 for this...don't think it's a steal, but thought price was reasonable.
« Last Edit: September 03, 2019, 05:41:58 AM by 574hondarider »
Offline bek1966
Re: '73 cb350f siezed barn find!
« Reply #1 on: September 03, 2019, 06:18:32 AM »
Nice 350f, I love these bikes!  Just this Spring I picked up a 1974 350f... out of a barn... from the original owner... unmolested... with about 10000 miles on it ...also seized - sound familiar? ;D.
I haven't gotten very far with it yet other than to remove the plugs and pour some Mystery Oil into it.  It also didn't budge, but I haven't tried more than a couple of times.
Thanks for sharing the pictures, I'm following along with interest.
Regards,
Brad
1971 CB750 K1 - Candy Gold
1971 CB500 K0 - Star Light Gold
1974 CB350 F1 - Glory Blue Black
1975 CB550 F0 - Someday "ProtoSport"
Pleasant Prairie, Wisconsin
« Reply #2 on: September 03, 2019, 06:32:09 AM »
Brad,
That is really similar!  We can go through the rebuild together then hahaha.  Thanks for the reply!
Offline Mark1976
« Reply #3 on: September 03, 2019, 07:01:54 AM »
For what its worth,
   Making a list is a great starting point, you have a great find there. Try to avoid dismantling anything at first. Keep soaking the cylinders with PB blaster or WD40, let time do its job first. Put a battery in it and find out what does and doesn't work. Then start making a list of what needs to be addressed on the electrics. Pull the carbs, clean rebuild and reinstall. All the while keep trying to carefully break the pistons free, it'll make pulling the topend that much easier if that's what has to be done eventually.  This is a great find and taking the time to carefully restore it to its original running state without any unnecessary tear down is a great place to start.
Start with the end in mind...
« Reply #4 on: September 03, 2019, 07:43:04 AM »
Will give this a try, thanks!  Would the wife's finger nail polish remover work (says it is acetone)?  I have fork oil but no atf, guess a trip to wal-mart is called for!
I will go ahead and remove the exhaust, be a good time to try to tackle some of the rust on it.
Keep the advice coming!!
Offline WhyNot2
  • I'm finally an
« Reply #5 on: September 03, 2019, 07:46:28 AM »
Nice bike........it may take a week or so to get it unstuck, but well worth the wait if it works.
I've got a 74, and can't get it to run at all, hoping you have better luck.
« Reply #6 on: September 03, 2019, 10:27:12 AM »
Buy a gallon of Acetone at Walmart.
will do!
« Reply #7 on: September 03, 2019, 11:03:56 AM »
Should I go ahead and order replacement insulator boots going from carb to engine?  I don't want to have to pull the carbs more than once, but the original ones looks decent currently (probably very hard though).
« Reply #8 on: September 04, 2019, 10:04:15 AM »
OEM carb rebuild kit and OEM boots ordered!  Now, if I want to get a 4 into 1 exhust, are the standard jets going to work?  I don't feel like making this decision now, but I am about to go through the carbs in a few weeks so I guess I need to order the correct jets if the oem ones can't handle it.
Acetone and ATF purchased, hopefully will have time to give them a dose tonight. I know it's 50/50, but how much fluid goes in each piston?
Thanks,
Bob
« Reply #9 on: September 04, 2019, 10:17:51 AM »
Thanks!  I hope you get your bike running, I will have to look for your thread to see what's going on with yours and if I can help.  Good luck!!
Offline K7-Steppy
« Reply #10 on: September 04, 2019, 10:18:40 AM »
Just throwing this out there the other day I started tearing down my cb350f engine which was also seized luckily for me after trying everything to get it unstuck I took off the alternator cover which apparently revealed there was a small leak where the wires entered and completely rusted out the rotor but once I got the cover off it spins freely now with ease. probably not your case but if you haven't already take off the alternator cover to see if you're in the same situation as me
Sent from my Pixel 3 XL using Tapatalk
« Reply #11 on: September 05, 2019, 05:20:36 AM »
Wow....that looks bad!!  I pulled the alternator cover and it looks mint...in fact, never seen one so clean!!  I wish that was true with the rest of the bike!!  Thanks for the tip and good luck!
« Reply #12 on: September 10, 2019, 10:03:36 AM »
I have been filling the cylinders every other day with acetone and atf, hoping that it will break free soon.  When it does, can I try to turn it over, or would there be potential of rust and junk on top of the pistons that I need to remove before I try that?  I don't want to damage the walls any, but would like to get a compression test before I tear it down.
Thanks,  Bob
will do!
« Reply #13 on: September 10, 2019, 12:22:40 PM »
After is releases, you'd best fill it with clean oil and filter, and pour a little down each cylinder to lubricate the bores before rotating the motor.
Will do, thanks!  Going to have to shop for some cheap(er) oil than my honda gn4 stuff that's on hand for this little trial run.
« Reply #14 on: September 10, 2019, 03:55:21 PM »
+1  make a cocktail of ATF & Acetone, pour a "shot" down the spark plug hole every couple days or so, be patient if you want this to work.  Keep the plugs out and then try to rock it back and fourth in 3rd or 4th gear, it should free up.
FYI - it is most likely not seized, that would be a mechanical failure. When these motors set for a long period of time, the piston rings rust to the cylinder wall...we call it "stuck". You need to "unstuck" it!
What brand of carb kits did you buy?  If they are not Honda, send em back!  [gaskets may be ok]
As a general rule, resist buying cheap china crap for your Japanese motorcycle!
The cheap stuff ends up costing you more when you have to replace it prematurely.
Good luck.
« Reply #15 on: September 11, 2019, 05:29:40 AM »
Good luck.
Thanks for the reply.  I purhased the genuine honda carb kits, and was hoping to use all the old brass parts.  All the engine seals I am buying are original honda as well.  I will start rocking the bike this weekend as you suggues, I have filled the cylinders with the mixture 4-5 times now in the last week.
I'm going to post a pic of the inside of the carbs as they are awful.  All gas has turned to hard varnish, so much that I can't get the main jet out and I don't want to damage the jet.  I used carb spray, then bp blaster, and this morning hit it with liquid wrench as that is what I had laying around.  I do have a sonic cleaner and a powder blaster, may give the sonic cleaner a shot to help remove the main jet.
« Reply #16 on: September 11, 2019, 05:33:31 AM »
Here's a pic of 40 year old gas turned to varnish.  Everything is frozen in place.  Bike has 17000 miles on it.  Will any of this be able to be re-used?  I was hoping to re-use everything but the o rings, but may need to look for new parts?  I guess really won't know until I get everything disassembled and cleaned.....
Offline WhyNot2
  • I'm finally an
« Reply #17 on: September 11, 2019, 06:01:35 AM »
yep, all the rubber is toast...........
every thing else is usable after a thorough cleaning of course.
Offline BigJimG
« Reply #18 on: September 11, 2019, 12:26:16 PM »
Another option I have used for varnished fuel in the past is Lacquer Thinner.  I just find a suitable container, coffee cans work nice for single carbs or pieces, and fill to cover the part.  Put the lid on the coffee can and leave it alone for a day or two while you work on other things.  Use gloves when working with it because it is NOT good for your hands/skin.
Some light agitation with an old toothbrush or similar after the soak will clean things up nicely.  Sometimes, if they are really bad or dirty, you may need to soak longer.
This will pretty much destroy all rubber components, but that's not usually a big deal since you were going to need to replace them anyway.
1972ish CB750 Chopper Project
Yet another CB Chopper frame
1972 CL175
1973 CB175
1975 XR75
1975 CB750F
1976 CB750F1
1977 CB750F2
1978 CB750F3  (apparently, now I have a full set...)
1991 XR80
« Reply #19 on: September 11, 2019, 01:23:31 PM »
Ultrasonic Cleaner with varnish remover in it will allow you to dislodge the jets. PB Blaster is worthless on cleaning varnished fuel- stop using it.
Soda blasting your carbs needs to be done carefully and hefty cleaning afterwards is required to unplug all tiny orifices of the media.
Will Jasco® Premium Paint & Epoxy Remover be safe to dislodge the jets and floats if put in the sonic cleaner?  Should I dilute with water?  Are the floats plastic or metal?  Will try this tonight if I can.
« Reply #20 on: September 11, 2019, 04:53:33 PM »
Vapor blasting is without doubt, the absolute best way to get to get old carbs to look better than new!
These old, nasty Mikuni's were sent to RestoCycle...
...and came back immaculate!
« Reply #21 on: September 12, 2019, 05:11:12 AM »
Yikes! I would not use that near my carb internals. Floats are likely plastic.
When I said varnish remover I was referring to varnished fuel, not varnish as a surface finish. The Lacquer Thinner might work well enough too. Berrymans carb cleaner dip is another great option.
Gotcha!!  Good thing I asked lol.  I might give Berrymans a try, I've heard good reports from others using it.  Thanks
« Reply #22 on: September 12, 2019, 05:12:26 AM »
Wow, thos look really nice!!  I want to clean them on my own though just for the learning experience, but those really do look good!!
« Reply #23 on: September 12, 2019, 06:08:11 AM »
Another question:  what hose is acceptable to use as the breather hose going from carb to carb?  I know there won't be alot of gas going through these, but I don't want them breaking down in a year or two if I can avoid it.
« Reply #24 on: September 19, 2019, 05:39:20 AM »
Progress!!!
After soaking the cylinder heads in 50/50 acetone and atf for about 2 weeks, last night I rocked the bike and heard a snap sound from around cylinder 4 and the fluid shot out (that's the good news).
The bad:  It seams I have no compression on cylinder 4.  With carbs and plug off, and no gas, I verified some compression just by plugging the spark plug holes with my finger.  Cylinder 4 has no sign of compression.  I inserted a wd40 straw and hit the starter and verified cylinder 4 movement, and looked in access areas to verify tappet movement both exhaust and intake, and I can feel it sucking from the carb insulator.  So I am thinking maybe stuck valve or snapped piston ring??  Any ideas??  Also, my kickstart still seams to be locked up, so there is something wrong there too.
I also was able to get all the carbs apart fully and working on cleaning them.
Thank you all for your suggestions!!!  I am new to this and wanted a learning experience, and I sure am getting an experience!!
Thanks!
-Bob
