Author Topic: Forgive me, I bought a 1980 CB750F  (Read 3712 times)
Offline tdskip
« on: September 06, 2019, 08:35:52 PM »
I mean come on, it’s been very well-kept (owned by a sensible adult and properly stored) for a whopping $750 so cut me some slack already.  ;D
But here is the thing, uou guys were so incredibly helpful on my questions when I was looking at a SOHC that you’ve ruined me. I’m sure I’ll see the light and come back to an earlier CB750  but until then I was hoping if someone could give me some tips on a good parts supplier for normal service items like brake lines, carb rebuild kit and that sort of stuff.  I’ve been to a couple sites that I found through Internet searches and a lot of the parts are listed no longer available.
Re: Forgive me, I bought a 1980 CB750F
« Reply #1 on: September 07, 2019, 01:36:36 AM »
Pretty.
As far as parts, did yo try ebay?  That's where I shop for my 82 CB900C.
Offline tdskip
« Reply #2 on: September 07, 2019, 04:28:20 AM »
Good morning, thanks for the note back.
Have you been happy with parts quality? eBay makes be skittish, maybe unfairly so.
« Reply #3 on: September 07, 2019, 10:51:33 AM »
I bought there insulators and air cleaner boots, Delkevic exhaust and master cylinder kit.    You can also find NOS on ebay, Honda made parts, never used.
Offline tdskip
« Reply #4 on: September 07, 2019, 01:17:51 PM »
Thanks.
Someone referred me to David Silver as well, need to check them out.
Online BenelliSEI
  • 1969 cb750
« Reply #5 on: September 07, 2019, 05:59:16 PM »
Good for you! Screaming deal for that price!
Offline tdskip
« Reply #6 on: September 07, 2019, 06:50:47 PM »
Hi there, thanks for the note.
Hope so, if it comes up as they forecast it will I'll be smiling.
« Reply #7 on: September 07, 2019, 11:48:15 PM »
Don't forget South Sound Honda of Olympia WA as they have probably the lowest dealer prices out there and are very reasonable on shipping charges. If it is still order able from Honda you should check their prices on their online parts ordering tool.
Congrats on your new bike and good price.
« Reply #8 on: September 08, 2019, 02:19:16 AM »
Also check with local Honda.  I wanted second key for the 900 and it took them two days from order to pickup.  Two key copies for $11, quite happy.
Offline tdskip
« Reply #9 on: September 08, 2019, 06:03:12 AM »
Thanks gentlemen, appreciate the tips and sources!
It looks like I can pull the side covers and seat off to gain access to remove the air box and carbs pretty easily, yes?
« Reply #10 on: September 08, 2019, 07:10:58 AM »
I have only worked on one dohc and it was a long time ago, but, I remember getting the carbs in and out as the hardest job I ever did and the airbox is so deep in the center of the bike, it is basically the last thing that can come out...pretty sure that is a main factor in why I have never purchased a non-runner dohc.
Offline nvr2old
« Reply #11 on: September 09, 2019, 09:10:41 AM »
I owned a 1980 750F back when it was new, and loved that bike.  It didn't come with a black engine or the front fender that's on yours which is from a 900F or 1100F.  I rode it from Spokane Wa. to So. Carolina and back without so much as a hiccup..70-90mph the whole way.  If you run it hard, keep an eye on the oil level.
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
« Reply #12 on: September 09, 2019, 09:18:55 AM »
  If the starter clutch is acting up and not catching all the time get in there and tighten up some screws on that assembly and add some loctite. Known problem on the 750 and 900F. I fixed my 900f with very little effort and saw firsthand the dilemma.
Offline tdskip
« Reply #13 on: September 09, 2019, 09:47:28 AM »
 Good morning gentlemen, thanks for the responses. I love how people have good memories of what all these bikes enabled by way of adventure.
Thanks for the eagle eyes on this – I did not spot that it had been modified. Do you think the engine was simply painted or does it look like it’s been swapped out for something else? I would imagine that front fender would be fairly easy to swap out if I wanted to, yes?
Offline nvr2old
« Reply #14 on: September 11, 2019, 11:06:45 PM »
I would keep the front fender.  Better then the original.  I would bet sometime in it's life the engine was painted, although following years came from the factory black.  You would know for sure by looking at the engine number on the title or registration.  Painting the engine black on mine was one of the first things I did to it.  More to make it resemble the 900F.  Really good bikes if they've been maintained.
« Last Edit: September 11, 2019, 11:09:20 PM by nvr2old »
Offline tdskip
« Reply #15 on: September 13, 2019, 07:04:02 AM »
Good morning and thanks for the note on the fender and engine.
This bike has sat for about seven years but was well maintained prior to that. She was stored dry of fuel (fuel drained prior to putting her in storage) for whatever that i worth.With that in mind;
- do you think it needs a valve adjustment due to sitting or should that be OK (leaning towards OK)
- brake lines and master cylinders likely OK still if the lines look fresh, or should I replace as a matter of waking her up
- ditto on fuel lines, thinking about replacing
Will pull and service the carbs, oil changes and new brake fluid, and of course need to check the date codes on the tires etc
Thanks and happy Friday gentlemen.
Thanks!
« Reply #16 on: September 13, 2019, 07:18:02 AM »
Rubber brake lines should be replaced every 6 years or 2-3 brake flushes as they degrade with time.  Braided Stainless Teflon lines are longer lasting and give superior feel and performance.
Offline tdskip
« Reply #17 on: September 13, 2019, 12:31:07 PM »
Stainless lines it will be then.
Anyone familiar with this vendor?
https://spieglerusa.com/brake-line-kit-523.html
« Reply #18 on: September 13, 2019, 12:47:35 PM »
Spiegler makes a top shelf product but if you want to spend less check Apex Brakes. Talk to Raymond.
Offline tdskip
« Reply #19 on: September 13, 2019, 01:04:59 PM »
Thanks for the referral
Offline Bankerdanny
  • Endeavor to persevere
« Reply #20 on: September 15, 2019, 07:41:40 AM »
I've used Apex and Spiegler lines. My most recent purchase was from Venhill US, which is based in Texas. Their system is nice because the ends screw on, so you can clock them exactly the way you need. The price was very reasonable and I had them in a few days. They have a web store on Ebay.
Offline tdskip
« Reply #21 on: September 15, 2019, 07:48:23 AM »
Good morning and thank you for the response. Hope you’re having a good weekend.
Good to hear that APEX is well regarded, someone local referred me to them and I was about to place an order on Monday.  I’ve been dealing with Raymond there who has been super responsive and helpful.
What do you guys think about clear stainless (Silver)  Lines versus black covers over the stainless lines ?
Thanks!
« Reply #22 on: September 15, 2019, 11:01:04 AM »
Clear or black,it is really a personal preference thing on what you want them to look like. Either would look fine. Some would not want the eye drawn to them on the black bike.  I do not mind it.
Offline tdskip
« Reply #23 on: September 16, 2019, 05:21:38 AM »
Thanks again, lines ordered!
Now on to everything else  :)
Offline 6adan
« Reply #24 on: September 28, 2019, 12:12:14 PM »
I thank Randakk's makes a carb rebuild kit for the DOHC. He has good products I have used them on GL 1000, GL1100, GL1200, GL1500 carbs with good results.
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
