Author Topic: Stator wire? 76 550  (Read 728 times)
Offline messeduptriple
Stator wire? 76 550
« on: September 08, 2019, 10:59:05 am »
Ok so I got the stator plugg switched from the incorrect one that came with the replacwmt motor. I have it all almost done finally with this project. I'm stuck now trying to figure this green wire. I don't see where it plugs in..I looked in the manual and I don't see any area where it pictures this and I'm kinda confused now. Where does this green red wire go? Does it need to be plugged in?
Any help would be great
-Cristian
Sent from my PH-1 using Tapatalk
Offline Scott S
Re: Stator wire? 76 550
« Reply #1 on: September 08, 2019, 12:00:42 pm »
 It's for the neutral switch. See right behind the wire, you can see a cam lobe of sort, with a screw in the center of it?
 Just above and to the left of that is the receptacle for the green wire.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Scott S
« Reply #2 on: September 08, 2019, 12:01:52 pm »
 BTW.... you have a whole bunch of threads going on relating to the stator wiring.  Maybe try to pick one and stick with it?
'71 CB500 K0
'81 Yamaha XS650
« Reply #3 on: September 08, 2019, 12:18:54 pm »
I thought I would post seperate issues that's why I did that but I guess makes sense to stick with one. I'll do that moving forward.
I'll have to look for that piece you said. Thanks again!
-Cristian
« Reply #4 on: September 09, 2019, 03:53:04 am »
-Cristian
I hate to bug but I'm not seeing anything to plug into. Did you mean that lil red part with the screw ontop?? I don't see any open plugs left :/
In the 3rd picture that's the only one I see where those plugs would go into but they are filled in. Maybe I just had an extra plug on this older one that didnt fit on this 550 and it's already plugged in?
Just not seeing where this open plug is.
-Cristian
Offline Scott S
« Reply #5 on: September 09, 2019, 06:03:38 am »
 Top picture, at about 12 o'clock.  Right below the screws hole in the case. See that little round receptacle?
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #6 on: September 09, 2019, 06:05:57 am »
 There's a screw hole in the engine case, and a Phillips head (JIS) screw in the pic. See the little candy cane looking thing between them? That's where the neutral wire plugs in.
 The thing with the red top is your oil pressure switch.
'71 CB500 K0
'81 Yamaha XS650
« Reply #7 on: September 09, 2019, 06:08:10 am »
Ahhhhhhhh
...alright...hell yea thanks Scott!!!! I'll tackle that this evening and get this all back together and hopefully finally get this riding. Thanks again
-Cristian
« Reply #8 on: September 17, 2019, 02:24:33 pm »
So I tried to fire up the bike and I have some issues but one thing I noticed was some leaking out the left stator cover side. I think obviously from the plug. Is there something I missed putting on? Why is it leaking and I have it on tight the cover?? When I took off I can push it in but it pushed back out a bit. Is this normal???
-Cristian
Online bryanj
« Reply #9 on: September 17, 2019, 03:09:18 pm »
That plug is in backeards, the flat dide goes inwards and the "tit" is held in by the cover. As it is now the "o" ring on it is not far enough in to seal on the machined surface
