Author Topic: CB350K3 - yeah, I know...  (Read 645 times)
Offline Knoxes
« on: September 09, 2019, 06:39:34 AM »
I'm just here looking for a pic, but the site won't let me search.  I'm guessing that's because I don't have enough posts?
In the last post on this thread:
http://forums.sohc4.net/index.php?topic=162263.0
tacc13 mentions that he posted a photo of some Tomaselli clip-ons that were drilled out for internal wiring.   I'm trying to figure out the same thing and it would be awesome if I could see that pic.
Offline jgger
Re: CB350K3 - yeah, I know...
« Reply #1 on: September 09, 2019, 06:57:16 AM »
Re: CB550 Project Start
« Reply #52 on: April 25, 2018, 01:12:37 am »
Bit the bullet and decided to run the bar wiring internally. I got some advice from the blokes at Revival Cycles as there is a small amount of modification required. I drilled a 4mm hole at the end of the bar and had to enlarge the internal diameter slightly. I used two cheap ebay tools for about $5 each. I need to make the exit hole a bit neater and larger so I can run the braided covering.
Is that what you were after?
Offline Knoxes
« Reply #2 on: September 09, 2019, 07:37:24 AM »
Ha!  Either I've screwed up the settings or this site is pic blocking me!
Thanks for the effort, but all I can see is:
etc.
This is really weird.  If I go into a thread, I can definitely see pics.
Offline Knoxes
« Reply #3 on: September 09, 2019, 07:49:48 AM »
Thanks for the time and date stamp, though.  I had to scroll and {CTRL-F}, but I eventually found the thread.
Offline jgger
« Reply #4 on: September 09, 2019, 12:29:14 PM »
It's not the site.........its my impeccable computer skills!🙈🙉🙊
