I ordered countersunk M6 from UK. They were a little but longer so I had to grind them off 2mm to avoid hitting the gear.
Cheaper than order locally Sweden
Edit: eBay has changed shipping since then so most likely not that cheap anymore. Find outside eBay is what I prefer today when shipping small stuff for £2-6 has often changed to £12 and less possibility to add parts of other part no to the order.
I replaced the other screws too with hex head M6 that I had home.
Same on 3 pumps. Drill heads off, remove cover and grab the screw with a plier and unscrew it. As I have done with many X heads on my bike, the trans shaft bearing holder included.
