Author Topic: 750f peg brackets on 550k?  (Read 511 times)
Offline steeldoncb550
« on: September 10, 2019, 03:08:35 pm »
Hi everyone! I searched and searched and just curious if 750f peg brackets will fit on my 77’ 550k. If they will fit, what’s all needed for the swap other then the brackets themselves. Any help is appreciated!
Offline Bankerdanny
  • Endeavor to persevere
Re: 750f peg brackets on 550k?
« Reply #1 on: September 10, 2019, 04:57:46 pm »
You mean the 77-78 style with the passenger pegs attached? Maybe. You would need to also source the matching lower bolt that goes through the driver pegs and lower engine mount then probably fab up some adapter to connect the upper mounting bolt to the top rear engine mount.
Online bryanj
« Reply #2 on: September 10, 2019, 05:12:15 pm »
I dont think the big alloy brackets will fit with the frame loops on the 550 but the only way to be sure is try it
« Reply #3 on: September 10, 2019, 08:58:02 pm »
Yes I was looking at a set off of a 78’. I would’ve thought someone from here has tried it before or know if it is a direct swap
« Reply #4 on: September 10, 2019, 08:59:23 pm »
I might give it a try and buy a set if I don’t hear that it won’t for sure work.
« Reply #5 on: September 11, 2019, 02:19:44 am »
Gotta ask why?  Most guys find these parts ugly and not very functional...
« Reply #6 on: September 11, 2019, 07:18:03 pm »
I like the look of them and they also set everything back like a rearset would
Online carnivorous chicken
« Reply #7 on: September 12, 2019, 12:32:26 am »
Wiht a little work, you should be able to mount CB400 (75, 76) pegs and linkage. Depends on exhaust. And might have to do some work on the brake lever. But they will set your pegs back 6 inches or so.
« Reply #8 on: September 12, 2019, 01:02:58 am »
as the owner of a 78 750f3, I can tell you, they won't serve as rearsets...same basic peg location as most other cb models, cb400f excluded
« Last Edit: September 12, 2019, 01:05:10 am by seanbarney41 »
