Author Topic: 77 CB750A. Top End gaskets.  (Read 631 times)
Offline evopgt
« on: September 10, 2019, 05:54:23 pm »
Hi All, This winter I’m going to be undertaking the top end rebuild , rings, and lapping the valves on the cb750A. Hopefully, the 28k mike engine will have cylinders within spec , so I can just hone them and swap rings. What Brand gasket sets have you all had luck with?  I’m seeing a Japan made Vesrah on the market. ?? Any luck with them ?? You guys suggest OEM rings? I’m sure there will be some other seals I’ll have to buy too.  I wasn’t planning on doing the studs, I heard they’re a #$%* to remove. Any one have luck reusing the stock studs?  Do you guys use copper spray on any gaskets or hondabond?  If so where at?? Thanks for any input.. It’ll be my first time doing a top end rebuild.
