Author Topic: Thoughts on cheap eBay and Amazon brake master cylinders  (Read 1692 times)
Offline tdskip
« on: September 15, 2019, 05:37:57 AM »
So I have another older bike that needs a new brake master and several people have pointed me at cheap new ones listed for sale on eBay. At the prices listed those units have to be Chinese made and frankly, that gives me a bit of pause since a brake master cylinder does a kind of important job.
Apparently some people have run them for years without issue but I wanted to check in here and see what you all thought.
Thanks in advance for the discussion.
Offline Scott S
Re: Thoughts on cheap eBay and Amazon brake master cylinders
« Reply #1 on: September 15, 2019, 07:43:21 AM »
 I've used them plenty of times. They're the same units that places re-sell at a higher price; MikesXS, CB750supply, Dime City, etc.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2 on: September 15, 2019, 07:45:35 AM »
I have had mixed results. The cheap rear master I bought for my 750F works great. The cheap front master I bought from a different source simply will not bleed out, so I went the other route and bought a nice new Nissin radial style for $140.
Offline tdskip
« Reply #3 on: September 15, 2019, 09:18:03 AM »
Thanks for the thoughts.
My time/prior focus on vintage cars may be biasing me here. Pattern parts are often terrible and especially on the British cars the Taiwanese parts are typically terrible quality.
It may be incorrect to apply that experience to parts for vintage Hondas....
« Last Edit: September 16, 2019, 12:17:52 PM by tdskip »
« Reply #4 on: September 15, 2019, 01:34:17 PM »
Most cases, I would say you would be correct.
Offline tdskip
« Reply #5 on: September 16, 2019, 12:43:45 PM »
Anyone familiar with Huri as a vendor?
Wonder how many of these all come from the same manufacturer?
Offline spotty
« Reply #6 on: September 16, 2019, 04:47:35 PM »
something as simple as that shouldn't be a problem, very few moving parts and as long as the seal does its job it should be fine
beware of the cheap radial brembo copies, they ARE cheap for a reason...ask me how i know this
i blame Terry
Offline tdskip
« Reply #7 on: September 16, 2019, 05:09:14 PM »
Thanks for the reply  and being patient - I know that I’m very-very close to over thinking this.
Offline tdskip
« Reply #8 on: September 18, 2019, 10:47:25 AM »
OK - so that part I posted showed up today and it seems to be good quality, will let you know if any issues are encountered in use.
Thanks gentlemen!
Offline Bankerdanny
« Reply #9 on: September 18, 2019, 03:37:30 PM »
Thanks gentlemen!
The generic Chinese import I bought looked good too, it even bench bled fine, it was only after I hooked up the hoses and tried to fully bleed the system i found that it wouldn't.
Offline tdskip
« Reply #10 on: September 18, 2019, 04:16:40 PM »
Chickens being counted, eggs un-hatched. Fair point.
« Reply #11 on: September 18, 2019, 06:37:29 PM »
 I put a 14mm one on my 79 gl1000 it was great. It came with a rebuild kit. That may mean something, or not.
Offline tdskip
« Reply #12 on: September 18, 2019, 08:29:58 PM »
Mine did as well, hopefully just because they are being thoughtful  :D
Offline tbpmusic
« Reply #13 on: September 19, 2019, 06:54:59 PM »
Working fine for me - and it doesn't leak !!
Bill Lane
« Reply #14 on: September 19, 2019, 11:57:43 PM »
Not all Chinese stuff is crap. Sometimes you find an inexpensive part built with good quality. Problem is there are lots of knock offs of the good quality Chinese part. Sorting out the cheap from the good quality parts is difficult.  The CX/GL500 forum has a eBay seller that has a good quality master cylinder. I will have to lookup the info and share the seller’s ID.
Offline Trevor from Warragul
« Reply #15 on: September 20, 2019, 04:00:30 AM »
I used this replica Honda CM450 master cylinder on my Morini 3 1/2 Sport.  Way better than stock.
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
Offline tdskip
« Reply #16 on: September 20, 2019, 04:37:27 AM »
Great discussion, I appreciate all of the responses and information.
I am waiting on my new stainless brake lines but will post a follow-up once I get this installed.
