Author Topic: tapered steering bearing kit  (Read 551 times)
Offline timbo
« on: September 16, 2019, 12:53:23 pm »
Hello,
After two years of delay I am finaly resuming my CB400F project.
I am ready to begin assembly but already have a problem.
I bought a tapered steering bearing kit from tour max SSH75-0. I read somewhere that
this would improve the bikes handeling. Somebody already instaled one of these?
There is no dust cover and the rod suddenly is to short to instal the top nut. I bought it with CMSNL and they
say it should fit. Just wanted to ask here before I start to make it fit.
regards
Tim
Offline jakec
Re: tapered steering bearing kit
« Reply #1 on: September 16, 2019, 01:13:33 pm »
This has been discussed a lot, I have had my own thread as well. did you get an all balls kit?
http://forums.sohc4.net/index.php?topic=176779.50
1970 CB750 K0 Stock
1970 CL350 K2 Stock
1975 CB400 F Stock
1977 CB750 F Hardtail
Offline timbo
« Reply #2 on: September 16, 2019, 01:52:11 pm »
No,its from Tour Max. made in japan.
Offline maxheadflow
« Reply #3 on: September 16, 2019, 03:36:20 pm »
It will only improve handling if your current races are damaged.
« Reply #4 on: September 16, 2019, 10:16:34 pm »
Tim, if the stem is suddenly too short to thread on the top nut, something is wrong!!! A common mistake is failure to fully seat the lower race in the bottom of the tube in the neck of the frame. It should be recessed deep into the tube, not just flush. Make a couple more posts, then attach some pictures so we can see what's going on.
Offline timbo
« Reply #5 on: September 17, 2019, 02:30:42 am »
The bottom race is al the way in the frame and fully seated.
The top race is a couple of mm potruding but that is supposed to be normal.
This kit is sold for manny models and my gues is that the spacer that goes under the bottom bearing is to thick.
I wil try to post some pictures this evening.
I was thinking on making a thinner spacer on the lathe.
Offline Kelly E
  • Geriatric Hooligan
« Reply #6 on: September 17, 2019, 06:14:36 am »
Both of the kits that I have used came with two spacers. Both times it required the thinner spacer. The instructions said to pick the spacer that makes the lower/race/bearing/spacer stack the same thickness as the stock bearings and races. I have done a 75' 400 Four and a 74' CB550 K.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline timbo
« Reply #7 on: September 17, 2019, 09:38:58 am »
Just one spacer in this kit and no instructions whatsoever.
