Author Topic: 1972 Honda CB 750 Rebuilt Carb Rack Question  (Read 287 times)
Honda3
« on: September 17, 2019, 05:51:44 pm »
Ive had it with these damn carbs that have been on my bike since 1972. A guy on ebay sells immaculately rebuilt carbs for $400 plus $23 for shipping.
I bought a set from him for my 1973 Honda CB500F and they are top notch. But....I didnt install them. The Mrs. limits my time in the garage and since I have 5 bikes, I cant do everything, so I farm it out.
Anyways, Ive never changed carbs on a 750 before. Whats involved? Is it straight forward? Im getting brand new front and rear rubber boots, so i'll just cut the old ones out when removing the carbs.
Is there anything else I need to know? Do I have to fiddle with the airbox of linkages or anything else?
I was on the bike today and its so fun, but the carbs still leak intermittently from the overflow tubes, onto the ground, missing the engine crankscase.
Carb rebuild in NYC is about $500 so may as well get the  "brand new" $400 rack from my cali dude.
Here is me and the bike today:
« Last Edit: September 17, 2019, 05:53:23 pm by Honda3 »
Re: 1972 Honda CB 750 Rebuilt Carb Rack Question
« Reply #1 on: September 17, 2019, 05:57:26 pm »
Save yourself $400. Its actually pretty easy especially with new engine and airbox rubber. They should slip on/off like butter -yes mine do exactly that. Just make sure you use OEM clamps and not the crappy aftermarket ones - yes it does make a difference. Remove the carbs and change the gaskets on the float bowls - super easy. Install and run. If idle is off make sure air screws are one turn out. Go for a ride and evaluate. i spent the first part of this summer doing all the above. It paid off. You will get there as well just be patient. Good luck and let us know how we can help.
« Reply #2 on: September 17, 2019, 05:57:56 pm »
Where are you in NY?
Offline Scott S
« Reply #3 on: September 17, 2019, 06:06:38 pm »
 Dude.... use one of the many other threads you have about this issue.
 And just put your Instagram in your signature already.
http://forums.sohc4.net/index.php/topic,179276.msg2079866.html#msg2079866
http://forums.sohc4.net/index.php/topic,178687.msg2074048.html#msg2074048
« Last Edit: September 18, 2019, 03:39:28 am by Scott S »
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
