Back in the day, if the idle hangs like that then falls off, it's typically the advance mechanism. It's hanging up. Clean it lube it. Make sure the springs are not loose. Servicing bikes with some miles, I'd pinch the hook on the advance springs with a pair of short needle nosed pliers.
For me, one of the ways to adjust the idle mixture screws was to set them all the same, blip the throttle, if the idle was slow to return, richen the mixture. If the idle dropped below set RPM, lean it out. Advance mech has to be working properly.
