Author Topic: Stator Coil Wire Broken  (Read 945 times)
Offline rusty_tank
« on: September 18, 2019, 11:06:03 PM »
Hi folks. I have a 1978 CB550K. currently both sides of the engine and the top end are taken apart. I'm slowly working on buttoning her back together. While poking around this evening I found that one of the wires on the Stator Coil is busted. I've included a couple pics. I'm under the impression that this is a fixable problem with a little solder and some shrink wrap but I wanted to confirm that first.
Re: Stator Coil Wire Broken
« Reply #1 on: September 19, 2019, 01:54:45 AM »
The wire might, probably is, enameled as most magnet wire is...so, that requires you to remove the enamel coating.  Retrieve an aspirin from your medicine cabinet, crush it and then insert the wire into the little pile of powdered aspirin.  Take a torch and melt the aspirin and it will remove the coating. Do NOT breathe the smoke from the aspirin.
Clean the wire end off with some acetone and then with some fine copper wire you an wrap the braided/stranded wire to the stator wire and resolder it.
David
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=kilphueb3uljrgs6fkne4jf4j2&/topic,60973.0.html
« Reply #2 on: September 19, 2019, 07:45:35 AM »
use sandpaper to remove the isolation..and solder new vires on..had glued the copper vire on the stator viring to hold it all in place,,use araldit..or special stuf for balancing rotors..all car elektro shops vho makes starters and generators/dynamoes had it..and thgen get it painted vith isalation primer..to seal broken or cracked isalation
i hate all this v-w.... vords
Offline rusty_tank
« Reply #3 on: September 19, 2019, 09:41:20 PM »
David
Guys thank you very much for your replies. They helped a ton. Cheers!
Offline rusty_tank
« Reply #4 on: September 24, 2019, 10:25:18 PM »
Got the wires all soldered up nice and good. Now, time to start a rebuild thread and put this damn engine together  :o
