Author Topic: Rust and torque  (Read 539 times)
Offline The Gurg
Rust and torque
« on: September 20, 2019, 10:50:34 AM »
Is this ok as far as corrosion? Obviously important holding the cases together. The bolt should be hidden behind the frame and side cover right? Should I change the torque at all with the corrosion? Should I replace instead?
Offline BenelliSEI
  • 1969 cb750
Re: Rust and torque
« Reply #1 on: September 20, 2019, 03:02:06 PM »
As long as the threads are good, no changes required. Looks fine!
