Author Topic: Rear wheel sitting crooked after bearing replacement, not fitting right  (Read 3866 times)
Offline Vesperia
Hello all,
I have a 1976 CB550 that I had a local motorcycle shop replace the rear bearing in the hub assembly. I noticed that after the bearing were replaced I am struggling to get the wheel and spacer on. I have to put the rear spacer on at an angle and force it into place, however the rear wheel sits crooked.
Has anyone encountered this issue or is it possible the bearing's are not sitting right int he hub?
Thanks for any help!
Offline Scott S
Re: Rear wheel sitting crooked after bearing replacement, not fitting right
« Reply #1 on: September 21, 2019, 01:23:26 PM »
 It looks to me like the wheel is bent, more than it's crooked. If you put the bike on the center stand and spin it, does it spin true or does it wobble?
 The only other thing I can think of is that it's surprisingly common for part #14 to come out stuck to the old bearing and it gets left out. This will cause issues as well.
https://images.cmsnl.com/img/partslists/honda-cb550-k2-four-1976-usa-front-wheelrear-wheel_bighu0038f4004_1d30.gif
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #2 on: September 21, 2019, 03:18:51 PM »
If the spacers are tight the bearings and or internal spacers are not assembled correctly and the bearings will be overloaded and fail prematurely
« Reply #3 on: September 21, 2019, 08:47:35 PM »
Looks like the swingarm itself is shifted to the right; the shocks look to be at an angle. The right side axle spacer is in place, and the brake backing plate seems to be sitting at the proper depth in the hub, so the bearings and or spacers are not the reason the center of the tire is so far to the right. Bent swingarm?
Offline maxheadflow
« Reply #4 on: September 21, 2019, 10:11:04 PM »
The swing arm looks bent to me.. Not sure how the wheel bearing change bent the swingarm.  Maybe it was bent before and you didn't notice?
Offline 1976cb750f836
  • 76 cb750f, 836, 78 wheels
« Reply #5 on: September 22, 2019, 05:30:29 AM »
Could the spacers be reversed? Or on wrong side?
Offline Vesperia
« Reply #6 on: September 22, 2019, 08:22:34 AM »
The wheel does wobble a bit, so it's very possible it's bent out of place. I would have thought the dealership would have told me when they put on the new tire and balanced it.
Offline Vesperia
« Reply #7 on: September 22, 2019, 08:23:46 AM »
I'll remove the swing arm and see if it's bent out of shape.
Offline Vesperia
« Reply #8 on: September 22, 2019, 08:25:04 AM »
I've actually never had this bike in running condition yet (bought 2 years ago as a project that didn't run) so I may have never noticed it as I was working on different items.
« Reply #9 on: September 22, 2019, 09:40:48 AM »
 loosen axle nut, see if  a gap appears., if the #14 spacer is out the sprocket carrier may sit in further and it looks like that.
then the swingarm may pull in tighter, bending one side or the  other.
Offline Redline it
  • thread killer
« Reply #10 on: September 22, 2019, 11:32:11 AM »
if you brought that to some kind of a shop, motorcycle, go kart or scooter shop and they did any work on it, and gave it back to you like it is now, i'd mark that on my list of not to take my bike to that shop again, or at least any shop. if there was something wrong or bent when you dropped it off, they should've said something then, but if they said ok pick it up, that explains why didn't say anything to begin with, and honestly, i'd ask em about returning you payment that went for service work. if they say no, bring your bike back and set up an umbrella outside of their store with a picket sign, they'll negotiate something. looks like they backed over it with a car. unless it was like that when you dropped it off.
it's difficult to find any shop that knows what's going on, or a mechanic that'll try to do it right. i got a friend that rode bikes when he was young. now he's past 60 and the first mc shop he applied to work for as mechanic hired him. his first project was a ktm open class or big bike motor size, for some trivial adjustment. my friend fixed it and decided he'd try it out in the parking lot. (he used to be able wheelie long distances any bike he'd get on including a 750 4, believe it or not standing on seat doing it.) so he gets on this newer ktm and looped it, (going over backwards,) on the asphalt. he got fired, right then, but the owner of ktm had to been kind of mad about that.
« Reply #11 on: September 22, 2019, 11:40:55 AM »
 I've seen 14 and 7 swapped too but that shouldn't cause a tilt, only off sides.
Offline Vesperia
« Reply #12 on: September 22, 2019, 02:43:07 PM »
I actually think I found the issue, the left side of the swing arm is bent slightly upwards. You can see the slight bump where it is bent.
I only brought the rear wheel to the motorcycle shop, not the entire motorcycle.
I'll have to get another swing arm, hopefully I can find a good one locally or on eBay.
Thanks for the help everyone!
« Reply #13 on: September 22, 2019, 03:19:14 PM »
Post a wanted ad with your location. Maybe someone close has one.
Offline Scott S
« Reply #14 on: September 22, 2019, 03:26:52 PM »
 I have a spare, but the very front "guides" for the chain guard are ground off, and I'm in South Carolina.
'71 CB500 K0
'81 Yamaha XS650
Offline Vesperia
« Reply #15 on: September 22, 2019, 03:55:25 PM »
I appreciate it! I live in Michigan so I'm a bit away.
« Reply #16 on: September 22, 2019, 10:22:16 PM »
Myself I would try to straighten it. can you show the tubing if it is crinked..
« Reply #17 on: September 22, 2019, 10:36:58 PM »
Frank, look at the tube just to the right of the chain guard mount. ;)
« Reply #18 on: September 22, 2019, 10:56:00 PM »
 I see it now. check the side of the axle plates there is paint missing. Put something flat against it, see if it's twisted.
« Reply #19 on: September 22, 2019, 11:13:09 PM »
How in the heck would a swing arm get bent like that??? Ves, you need to take a closer look at the rear wheel. Why did you have the bearing replaced? Was it totally fubar???
Offline Vesperia
« Reply #20 on: September 23, 2019, 04:10:45 AM »
The bearing on the bad arm side was shot, I'm going to guess during some point in moving or transport it got bent but it could have been like that when I bought it and I never noticed.
Offline Scott S
« Reply #21 on: September 23, 2019, 04:15:24 AM »
 It would take a helluva whack to bend that arm like that. Is there any evidence of other damage on the bike? On that same side?
'71 CB500 K0
'81 Yamaha XS650
Offline Vesperia
« Reply #22 on: September 23, 2019, 04:38:10 AM »
I'll give it a more thorough once over after I get back from work, as far as I could tell no.
« Reply #23 on: September 23, 2019, 06:07:33 AM »
Somebody playing evil knievel
Offline Kevin D
  • SE Michigan
« Reply #24 on: September 23, 2019, 07:44:06 AM »
Sounds like fun! I busted a couple spokes hurdling a RR grade on my CB, just once, long ago. Lucky for me the broken spokes were rear outside. My dirt bike was much more suited for jumps and went airborne as often as possible, but no bent swingarms on CB or SL. All landings square to ground as well.
Where are you Vesperia? Slicks in Mason used to have a pretty good salvage operation. I don't know if their new place in Dansville got the salvage yard.
Member Yamahawk in Toledo has salvage parts available and might steer you to Ohio MC salvage yards.
Its been a while but I have been to CycleReCycle in Indianapolis. They have lots of used parts.Call them with your needs.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
