Author Topic: Too much Threebond 1184?  (Read 1094 times)
Offline The Gurg
« on: September 23, 2019, 12:29:48 PM »
Watched several videos to try to get the correct amount of Threebond. Wound up having a little ooze outside the case. Is this ok?
Second photo of the inside of the case. Red X is assembly lube, black circle is the Threebond.
« Last Edit: September 23, 2019, 03:04:16 PM by The Gurg »
Re: Too much Threebond 1184?
« Reply #1 on: September 23, 2019, 04:43:39 PM »
That's the beauty of threebond, it will bulge out a little and not shear off inside. It looks good to me.
« Reply #2 on: September 23, 2019, 09:11:36 PM »
 I just took a VW case apart and it was swimming in silicone. I'd bet there were 3 tubes in it between the case, the oil screen plate and all 8 pushrod tubes. I found a red anerobic case sealer. I hope it works, it looked too much like the assembly lube which was disturbing.
« Reply #3 on: September 24, 2019, 05:48:10 AM »
 Looks good to me too.
Offline The Gurg
« Reply #4 on: September 24, 2019, 08:10:07 AM »
Awesome thanks all!
