Author Topic: Pods on a 1978 550K  (Read 1404 times)
markmc
Pods on a 1978 550K
« on: February 02, 2007, 02:09:12 pm »
It seems that the pod on my #2 carb is interfering with the movement of the choke lever.  Has anyone else had this problem and/or found a solution?  I'm not sure what brand of air filters I have, they were purchased from the Parts'n More website.
https://www.partsnmore.com/cat_index.php?model=cb500&category=carb
Any info is appreciated.
Offline shoemanII
  • just another bike nut
Re: Pods on a 1978 550K
« Reply #1 on: February 02, 2007, 04:52:12 pm »
had a similar prob on my '78 750k, chrome base of pod on carb #2 would not allow any movement of the choke.  i sent the set back for a full refund and put the old aftermarket air filter back on.  found out after the fact that i might have been able to bend the choke lever a tad.  be careful if you try this.  put the refund $ into a braided brake line while i shop for pods.  uni filters pk-52 may work for me, check their site.  good luck!
bobp
'96 ducati carb'd 900ss/cr
'72 dt2
'77cb550k frankenberry:  '77cb550k frame, '78cb550k engine, '78cb550f tank, unknown front-end
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #2 on: February 02, 2007, 04:53:35 pm »
Yup, should be able to bend it a slight amount to avoid contact with pod
Offline cafe75-550
« Reply #3 on: February 03, 2007, 12:59:21 am »
The K&N filters I bought for my 75 550 K say in the directions that the choke lever has to be bent slightly to work properly with the pods. Make sure that when you do this you only bend the lever, and not the linkage. I bent my choke lever slightly and now have no clearance problems, and everything seems to work just fine...
New bike!
'07 Triumph Speed Triple 1050
Never enough projects!
'75 CB550 "Cafe", '76 CB550 parts bike
'64 Norton Atlas featherbed/'71 Triumph 750 Triple (Triton project)
'68 BSA Thunderbolt (frame and cases, project in the wings)
'57 Triumph Thunderbird (frame and mostly complete engine)
markmc
« Reply #4 on: February 04, 2007, 06:20:41 am »
A little bend worked perfectly.  Thanks for the advice.
Offline shoemanII
« Reply #5 on: February 04, 2007, 06:34:35 am »
now that i know the pods i sent back can fit by bending the choke lever, i may reorder them.  just wondering tho, carb intake diameter is 46mm and pods were 42mm (partsmore same diameter).  i remember they fit but freakin' tight.  anyone have a problem with splitting the boots?
many thanks!
bobps
'72 dt2
markmc
« Reply #6 on: February 06, 2007, 05:37:25 am »
I can only speak for the '78 550, for which the correct pod dia. is 39mm.  They can easily be pushed on, so tightening the clamps are essential.
