Author Topic: One pipe not warming up the same as others! CB650  (Read 390 times)
Offline raiken1
« on: September 25, 2019, 08:12:55 AM »
I just finished most of my tune-up/rebuild of my 1981 CB650 and have started having a new issue. It seems like one issue goes away and a new one starts. Previously the bike would idle well and then when given throttle it would hand at high rpm. All 4 pipes were heating up the same amount. I decided to take the advancer out and clean it then lube it with engine oil. I reinstalled it and put the timing back where it was before. Now, the bike will not take any amount of throttle without dying. The header on Cylinder 1 is only getting warm after 3-5 minutes of idling as well. I pulled the plug and it arcs off the engine head. I still need to do a leak test and carb sync, which were next, but this cylinder 1 issue has started. What should I look at next?
Here is what I have done thus far:
-Professional carb rebuild bike a vintage bike shop- Ultrasonic bath, pilot jets cleaned with guitar string, new seals and other jets etc are new (All parts from K&L carb rebuild kits) - Stock jet sizing 120 mains - Carbs were bench synced
-Brand new Vacuum tees between 1-2 and 3-4
-Rebuild kit for accelerator pump
-New Carb boots
-New Plugs and wires
-Set pulser gap to .3mm
-Set valve clearances
-New filter (I have a stock paper filter and a uni foam filter) - original airbox
-Mac 4 into 1 exhaust with megaphone muffler (Original exhaust was rusted)
-Checked static timing
-New fuel filter (Although testing without it - Auxiliary fuel container)
-Cleaned inside of fuel tank
-Set mixture screws to 1.5 turns out
- Lubed and cleaned advancer
-Oil change
Offline bender01
Re: One pipe not warming up the same as others! CB650
« Reply #1 on: September 25, 2019, 05:58:41 PM »
Rap that carb with a screwdriver handle! Sticking float? Pull the float bowl drain screw and see if fuel is coming out.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline Gene
  • Chat enuf you too can be a
« Reply #2 on: September 25, 2019, 06:03:59 PM »
Yep - start with the easy stuff ^^^
Make sure you have fuel in that carb.
*1973 CB750K3 (Bow)
Offline raiken1
« Reply #3 on: September 26, 2019, 08:59:27 AM »
Thanks for the replies! I will tap the carb with something plastic and drain the fuel. Will update once I’m done. I have to clean up some spark plug threads first today.
