Author Topic: Final drive deal seating  (Read 348 times)
Offline The Gurg
« on: September 26, 2019, 08:01:45 AM »
Does this seal need to be redone? The case has been bolted down with Threebond. The seal has Threebond around it as well. What are my options?
Re: Final drive deal seating
« Reply #1 on: September 26, 2019, 08:49:55 AM »
Is it leaking?
Offline The Gurg
« Reply #2 on: September 26, 2019, 08:54:08 AM »
I haven’t added oil, I’m mid rebuild on a cb750 K5.
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: September 26, 2019, 10:48:46 AM »
New seal? Can you get a wood paint stir stick in there? Then pry between the wood and the gear with a screwdriver and see if the top of the seal moves in a bit? Otherwise, leave it alone. It is unlikely to leak, and no harder to change when it is in the bike, than on the bench.......
