Author Topic: Anybody interested in ordering a 970 kit???  (Read 2774 times)
« on: February 02, 2007, 03:18:44 PM »
Was talking to a guy at Arias. 600.00 for pistons, rings,pins and c clips....any compression ratio. These would be custom made....3 sets and the price goes down. You would still need sleeves and head/base gaskets. I didn't say it was cheap but at least they would be more modern.
Offline kghost
Re: Anybody interested in ordering a 970 kit???
« Reply #1 on: February 02, 2007, 08:49:53 PM »
Now I am intrigued
Stranger in a strange land
Offline Big Jay
    • CBRzone
« Reply #2 on: February 02, 2007, 09:33:00 PM »
That is about the going rate for custom pistons.  You can remachine used Kawasaki Z1 sleeves to fit.  You will certainly need rods.
Jay
« Reply #3 on: February 03, 2007, 05:37:17 AM »
Jay
All set on the rods. I have the dimensions for the sleeves...either LA Sleeves or Advanced can custom make them. I'm not really fond of Arias but they used to make these pistons and don't need dome dimensions, relief placement etc. I'm sure they would use up to date material as well so you don't need an inch of skirt to wall clearance. I'm contemplating here ;)
« Reply #4 on: February 03, 2007, 09:34:03 AM »
Mike,
Will they give you a firm price for 3 sets? At what point might they lower the price even further? PM me if you need to.
Offline kghost
« Reply #5 on: February 03, 2007, 11:09:53 AM »
I'm curious if they all need to be the same.
If so what C/R were you thinking of Mreick?
« Reply #6 on: February 03, 2007, 03:55:30 PM »
I was thinking of 10:25 dome so I could deck the cylinder to 0. It would go about 10:5 in the end with head surfacing and the decking. I'd use a 78 head I have. the chamber is better though larger. Christ... I'd do all sorts of measuring before I put it together
Offline Soos
« Reply #7 on: February 03, 2007, 04:59:58 PM »
I posted a mention of this therad over at satanic mechanic hoping someone there would be able to help with your price break order min. of 3 sets....
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline Big Jay
    • CBRzone
« Reply #8 on: February 03, 2007, 09:00:24 PM »
Jay
I know that LA Sleeve has a part number for that sleeve, but are youi aware that their sleeves can now run close to $70.00 ea. Advanced is even more.  The 70 mm piston in a Z1 Kaw was a very popular mod and they held up well bored that big. There must be thousands of them out there that have been removed from blocks to make really big motors. I am sure we must have a bunch. About an hour on the lathe and you have big bore Honda sleeves.
Jay
« Reply #9 on: February 03, 2007, 09:24:00 PM »
Jay
Jay
Thanks Jay...good info. I'll ask Stetson if he has any lying around.
  Mike
Offline Jim F
  • go baby go
« Reply #10 on: February 04, 2007, 07:24:29 AM »
I run  Arias Pistons in my GS 2 valve motor in the order of 840 cc and had had plenty of  "front tire in the air and the back end kicks out fun"
with no problems
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline Geeto67
  • A grumpy
« Reply #11 on: February 04, 2007, 08:56:41 AM »
are these forged or cast pistons?
Maintenance Matters Most
« Reply #12 on: February 04, 2007, 12:42:36 PM »
Forged
Offline Hockers Choppers
  • go away winter!!!
« Reply #13 on: February 04, 2007, 03:23:23 PM »
Hey Mike, I have started a thread on cr carbs, but wanted to ask you if you knew of a place to get a good deal on a set?
The thing about common sense is that, it's not that common.
1978 CB750F SUPERSPORT 850cc, cam, porting, dyna ign, cr29's lotsa elbow grease and $$'s. Worth ever penny!!  (S0ld)
05 VTX1800F darkside
cb750 k1
  • go away winter!!!
« Reply #14 on: February 04, 2007, 03:26:20 PM »
good deal on a set of cr carbs????
cb750 k1
  • go away winter!!!
« Reply #15 on: February 04, 2007, 03:33:17 PM »
cb750 k1
