Author Topic: 1971 CB500 Seat Lock  (Read 462 times)
Offline 34barab
« on: September 28, 2019, 02:16:16 PM »
Attached pics show the seat lock.  I have a key with matching T number, when turned CCW 1/2 turn, allows access to under the seat.  The key does not pull out until you turn the key 1/2 turn CW to lock it.  The question is are these seat locks serviceable?
The key comes out easy enough, but it's a struggle inserting it......sometimes.  I've cleaned the lock with carb cleaner and WD40, air dried it and lubed it with 3 in 1 oil.  I suspect one of the tumblers has a rough edge, maybe from being forced at some point.
Is there a way to open these locks?
Current Projects: 1973 CB750K3; 1972 CB350K4; 1980 CX500D;1969 CB750.  Roadworthy: 1971 CB750K1
Re: 1971 CB500 Seat Lock
« Reply #1 on: September 28, 2019, 04:11:38 PM »
Not easily, you can fit the later type lock as long as you fit the lock bracket and seat to match.
The very early ones like you have are getting very hard to find now, i just had to import a nos lock bracket from Germany to UK  and pay a lot of money for it ( about $100).
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: September 28, 2019, 05:19:39 PM »
Have you tried “powdered graphite”? It’s just what it says and often used for working sticky locks. I often visit an old style (old guy) locksmith with problems like this. He picks around with his tools and often can solve a problem in a few minutes....... good luck!
