Author Topic: Smoke, workable or serious issue  (Read 539 times)
Offline Ace Blackwell
  • 1977 CB550F - Resurrection in progress
« on: October 01, 2019, 07:03:10 PM »
Tonight I installed my Cone Eng Quiet-er muffler. I have to say I was impressed . It really did quiet the bike considerably. I started the bike. It’s only the second time since redoing the carbs. Also I haven’t clear tube tested or vacuum synced yet.
Unlike my first time firing it up a few days ago, the smoke was pretty heavy. Not “can’t see the bike for the smoke” heavy but still pretty thick. The smoke is gray in color. Not sooty black or bluish white.  Just a constant gray smoke.  Is this something that can be adjusted/worn out or am I looking at major surgery?
Few more points. The tank has about a gallon of fresh gas but it was coated in marvel mystery oil. As I said the muffler is new. Not sure if it would have a break in period. Lastly all 4 pipes were hot. I assume that means all 4 cylinders are firing at least part of the time.
I’m including a small file to show the smoke and maybe to the trained ear, it might have a tell tale sound. Not sure why it was so dark, it wasn’t as late as it looks
Thanks
1977 CB550F Work in Progress
Re: Smoke, workable or serious issue
« Reply #1 on: October 01, 2019, 07:14:06 PM »
If you got oil in your gas, its gonna smoke...until all the oil is ran outta there
Offline maxheadflow
« Reply #2 on: October 01, 2019, 07:32:00 PM »
If it's cool and humid, you'll get a grey fog til' the motor warms up.  It's condensed H20.
« Reply #3 on: October 01, 2019, 08:48:47 PM »
 Have you put any actual road miles on it yet ? Can't tell much till then .
« Reply #4 on: October 02, 2019, 04:59:02 AM »
No, no road miles yet. Still have a lot to do before it will be safe to ride.  I may put the chain on and run around the neighborhood just get it rolling. I think I’ll drain the tank and slosh some fresh gas around to clean out any oil and see if that helps.  As Max stayed, some could be steam but it’s been 80-90 here in Ky, plus the gray eventually fills the yard so I don’t think much of it’s steam.
Thanks all
