Author Topic: Safest way to raise the front wheel / fork removal  (Read 2913 times)
Offline my name is nobody
  • I like Pontiacs and Hondas
« on: October 06, 2019, 06:55:13 AM »
How do you all do it without tipping the bike over? Once the bike is raised in front, how do
you secure things? Can it be done (cb750) on a harbor freight 1000 lb. lift? or is there a better way?
It spooks me going back on the center stand, but if there's no other way, well....I have nothing
overhead to assist/lift with. Suggestions greatly appreciated, thanx folks...
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
Re: Safest way to raise the front wheel / fork removal
« Reply #1 on: October 06, 2019, 06:59:34 AM »
I just use a scissor jack with a block of wood under the oil pan. I put another block behind the rear wheel just to make sure it doesn’t go that way.
Hasn’t caused a disaster .... yet  :)
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
« Reply #2 on: October 06, 2019, 07:12:46 AM »
 I put it on the centerstand and support and raise the bottom of the engine around the oil filter area with a jack and a block of wood and then when I leave if front still off brace the front with a 2x4 or other piece of wood under the front frame section.Worked well on many bikes.
Offline Bodi
« Reply #3 on: October 06, 2019, 07:41:13 AM »
Pretty much on the centre stand and either a jack or whatever (like a 2x4 cut to fit under it tight) under the oil filter housing. I do have a strongpoint in my shed rafters where I can lift a front end (or an entire bike excepting super heavy ones like a GL or Amazonas) with a chain hoist, but that puts it right in centre and kinda in the way.
Not sure about a 750... many bikes will sit free on the centre stand with the front end off but it isn't very secure, the weight balance is close and pushing down on the steering tube can cause the bike to fall. I have put a bike with no front end on a furniture dolly that just fits the stand and rear wheel so I could move it out of the way, but I strapped the rear wheel down.
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: October 06, 2019, 08:08:33 AM »
Use a wood/jack, like everyone suggests. If working on the floor, add a short ratchet strap from the side crank on your centre stand to a forward point, on the frame. Snug it up, so there it’s NOT POSSIBLE for the centre stand to flip backwards and up.......
Offline Kelly E
  • Geriatric Hooligan
« Reply #5 on: October 06, 2019, 08:18:22 AM »
On the centerstand and I have the scissors jack with a block of wood under the base of the oil filter housing to lift it. For insurance I put the front axle back in and stick a small jackstand under the axle. Even though the bike is strapped to the lift I still do it.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #6 on: October 06, 2019, 09:37:55 AM »
I also have a block of lead I place on the floor and tie to the rear frame just to make sure it stays "reared up"
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #7 on: October 06, 2019, 10:16:07 AM »
Not safely.  I almost had a disaster happen trying to remove the rear wheel on my H2 on the HF lift [H2 has no center stand]. The rear of the lift started coming up when the rear wheel was lifted up! Whoa!!
My preferred method is using a 4" ratchet strap attached to the angle iron bolted to the ceiling joists in my shop [but you said you have nothing overhead]
« Reply #8 on: October 06, 2019, 11:00:45 AM »
thanks gents...This definately helps. I will report my solution when I get it down off the rack.  :)
Offline spotty
« Reply #9 on: October 06, 2019, 08:42:52 PM »
another option if the side stand has been sacrificed to the gods of weight saving is tip it over on the side stand and put an axle stand under the frame tube on the other side as far forward as you can, this will tip the weight backwards onto the rear wheel and get the front off the ground
i'm not saying its the most stable  method in the world, you wouldn't want to be doing an engine swap but it works well enough to get the wheel or forks out
its less stable using the same method for the back wheel but again it works well enough to adjust the chain, i have done a rear wheel change though it didn't feel the safest, especially on my own
i blame Terry
Offline 1976cb750f836
  • 76 cb750f, 836, 78 wheels
« Reply #10 on: October 07, 2019, 05:32:28 AM »
I remove tank, hang frame on a cherry picker. Or I have used ceiling hook and come a long, or ratchet straps. I have no center stand.
Offline Jore
« Reply #11 on: October 07, 2019, 10:30:04 AM »
I have no centre stand as well, but when I did the front end I used ratchet straps tied to an all metal staircase I have, i also know a guy who uses an a-frame ladder with similar results
1975 CB400F owner
-Having a vintage motorcycle is like having a moody girlfriend.
My 466 build: http://forums.sohc4.net/index.php/topic,146494.0.html
« Reply #12 on: October 07, 2019, 05:18:10 PM »
I ended up cutting a piece of 2x4 that was the same length as the engine is wide. it fit a little tight between the frame rails.
i located it just rearward of the oil filter housing, and used my harbor freight trolley jack to raise the bike. It was more stable than I expected
but had my son close by in case anything went bad. Worked out great. If I had a choice I'd use the overhead lift method tho. Thanks for all the different suggestions/methods. Hopefully someone can use this information and apply it to their particular equipped type bike 8)
Offline rosewood
« Reply #13 on: October 07, 2019, 05:49:12 PM »
This may be a little late to the discussion but I managed to assemble my whole bike solo with the use of this trestle style ladder and ratchet straps. have used it several times since and has worked very well...
« Reply #14 on: October 08, 2019, 05:30:22 AM »
I like that idea!
Good if you’re only working on the front end, but it must restrict access to the rest of the bike.
CB450 K1 - Stalled.
Offline Gene
  • Chat enuf you too can be a
« Reply #15 on: October 08, 2019, 04:01:34 PM »
I know you've gotten a lot of good replies here, just want to iterate that the jack with a block of wood is the way I've done it. And like ekpent said earlier, a little insurance under the front if you're walking away for a while.
*1973 CB750K3 (Bow)
Offline pjlogue
« Reply #16 on: October 08, 2019, 04:51:16 PM »
I agree a jack and block of wood is the easiest.  Don't leave the jack supporting the bike unattended.  If you need to leave it for some time put blocks under the bike just in case the jack's seals aren't good.
-P.
Offline Kelly E
« Reply #17 on: October 08, 2019, 09:08:35 PM »
I use a scissors jack from the wrecking yard instead of a hydraulic jack, no worries about leaking and easy to work with.
1983 Honda CB 1100F
Offline PGF550F
« Reply #18 on: October 08, 2019, 09:44:42 PM »
With my 750 on the Center stand, I use an adjustable jack stand directly in front of the engine and supported the front end on the frame just below the steering tube/ neck.
 It is way more secure than the janky setup I ran with when I rebuilt the forks and changed the tire on my 550. I guess I learned from that experience.  ;)
« Reply #19 on: October 09, 2019, 05:16:14 AM »
I re read this thread and discovered that the method
I used is very similar to the one Bodi suggested. Didn't register till after I was finished. I just studied
the whole situation a second time and went to work. But the contents of this entire thread helped me
look at things a second time through other's experiences. A lot of times, ideas are mentioned that involve
use of common household items (like the ladder) that one might normally not realize as part of a
cool solution to a particular challenge, and it's right in plain sight. I still use caution, but am much more confident than before. These are all excellent ideas.  8)
Offline Deltarider
« Reply #20 on: October 09, 2019, 07:07:27 AM »
I like that ladder. Brilliant idea. I myself do it like this:
1) I have a wooden block ready that's exactly the right size.
2) My hands under the front fender raise the front and keep it up there for a second...
3) ... in which my right foot slides the wooden block under the front of the engine. Done.
No ladders, no jacks, just a wooden block. Maybe a CB750 will be too heavy. Works for a CB500/550 though.
CB500K2-ED Excel black
« Reply #21 on: October 09, 2019, 08:38:36 AM »
 I added some u bolts to my harbor freight lift so I can tie down in the back or middle too, that way I get some safety factor when removing either front or rear ends.  I use an old but reliable scissor jack and put a small piece of plywood under it and the center stand for a softener to provide traction, and use a set of light duty pull down straps that stay with the lift.
Offline mattsz
« Reply #22 on: October 09, 2019, 09:47:55 AM »
No advice to add to what has already been said... just a funny story:
I had both wheels off a bike once - on the center stand, rear wheel removed first.  Then I propped the front of the frame up with a piece of wood and removed the front wheel - it all looked just a bit dicey, but I actually was surprised how stable it was working on the bike with both wheels off.
As it was front-heavy even without the wheels, it seemed fine without any support beneath the rear end, just the two-point center stand and single front brace - until I made the mistake of casually leaning on the seat - I think I had the manual open there. The bike slowly tipped back - not enough to dump it, but just enough for the front brace to drop to the floor. And there I was, holding the bike, with no wheels, balanced on just the center stand, wondering what the heck are you gonna do now, dumbass?!?
There was a plastic milk crate just close enough for me to reach out with my foot and slide it beneath the rear end to help hold the bike steady enough to reset the front brace - after which I promptly made one for the rear, propping it up by the axle in the swingarm as well...
« Reply #23 on: October 09, 2019, 11:27:32 AM »
 In my younger days I made the mistake of taking both fork springs out while the bike was if I remember was on the side stand. Big mistake ! Even on the center stand your asking for trouble if you take out both with no front end support.
« Reply #24 on: October 10, 2019, 04:56:42 AM »
I have also used automotive Jack stands under the engine while doing front end repair. Using a thick shop rag as a pad, 1 under point cover, 1 under flywheel cover.
