Author Topic: Emulators  (Read 2636 times)
Offline maxheadflow
Emulators
« on: October 09, 2019, 06:31:24 PM »
Anyone using this emulator?
https://www.vintagecb750.com/products/3/suspension-wheel/52/fork-tubes-springs-seals-boots
I've used the RT's for a few setups.  Price for the valve does seem a little high for a 40 year old mod.
Re: Emulators
« Reply #1 on: October 09, 2019, 06:39:04 PM »
Main thing you are paying for from RaceTech is access to knowledge of how to set these parts up for your specific needs.  If you are not knowledgeable with how to adjust your emulators, you can actually make your suspension worse.  Not saying you are or you are not, but real good help is available from RaceTech.
Offline maxheadflow
Re: Emulators
« Reply #2 on: October 10, 2019, 12:43:50 PM »
One thing to note is that I've done RT emulators on 4 different bikes, also had them setup front and rear forks for my XR400 and have used one gold valve kit.  Some of their recommendations were off and I ended up going back into the forks.  Instructions have been getting better tho.
Offline Steve_K
Re: Emulators
« Reply #3 on: October 14, 2019, 02:52:58 PM »
I have used RT emulators in my 86 750 GIXXER and a SVS650 and I got great results and was very happy with them.  The instructions were good, though I did need to work with spring pre load.  I also used the RT springs for my weight in the forks.
Steve
Steve_K
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
Re: Emulators
« Reply #4 on: October 18, 2019, 04:09:14 AM »
Ignorant and curious; what are emulators?
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
Offline maxheadflow
Re: Emulators
« Reply #5 on: October 18, 2019, 08:39:28 AM »
Offline JoeDuc
    • V4 Dreams
Re: Emulators
« Reply #6 on: October 22, 2019, 11:53:03 AM »
Emulators take our old, simple forks and "emulate" more modern cartridge forks. A real improvement.
Offline maxheadflow
Re: Emulators
« Reply #7 on: October 22, 2019, 04:40:54 PM »
I think one point to note is that the emulator only "emulates" a cartridge fork on compression.  Rebound is still the same.
Re: Emulators
« Reply #8 on: October 22, 2019, 05:26:24 PM »
How much does it cost (approx) to send forks to RaceTech for emulator install? Anyone done this? I have 2 sets of spare forks lying around.
thanks
Andy
Offline maxheadflow
Re: Emulators
« Reply #9 on: October 22, 2019, 05:56:41 PM »
thanks
Andy
https://racetech.com/ProductSearch/12/Honda/CB750K/1977-78  About mid page.
Re: Emulators
« Reply #10 on: October 22, 2019, 06:01:32 PM »
The install is pretty easy, especially with provided instructions.  The adjustment is more difficult, but really just requires careful and honest measurement.  And once again, technical help and basic instructions are provided, with additional just a phone call or email away.  This is why I recommend spending the extra money for genuine racetech stuff.
Re: Emulators
« Reply #11 on: October 23, 2019, 02:56:40 AM »
thanks
Andy
Thank you!
Offline maxheadflow
Re: Emulators
« Reply #12 on: November 06, 2019, 08:12:03 AM »
FWIW, I bought the cheaper emulators.. Machining on the parts was good but IMO they had the wrong springs for the top valve.  The springs included were 64lb/inch which are a little stiff.   For the street RT suggests 40 lb/inch which I happened to have from another install.   Measurements were taken at 0.3 inch compression. Given that the gauge resolution is only 2 lbs. The springs were real close to advertised if you add 2 lbs to each reading.
I also added a second low speed hole.
I also added a brass spacer at the top to get a more consistent reading on spring compression and polished the screw shaft.
« Last Edit: November 06, 2019, 08:13:50 AM by maxheadflow »
Offline maxheadflow
Re: Emulators
« Reply #13 on: November 06, 2019, 08:24:39 AM »
I drilled the holes in the damping rod.
I checked the stock springs for rate and volume. The rate is about 0.79 kg/mm which is closed to what is recommended but the spring were to long when the emulators were added. Also the springs are much thicker than what you get from RT so I had to measure the volume the spring occupies to adjust the oil level in the tube. Found some PVC that had the same ID as the fork tube. It turns out that the spring fills up about 152mm of the tube for the 130nn recommended 130 they had was way too small volume. I added 24mm for the cap and spacer then a little more and figure 185mm was a better number.
Offline maxheadflow
Re: Emulators
« Reply #14 on: November 06, 2019, 08:31:36 AM »
Forks have about 130mm travel. I measured the sag before disassemble and got 40mm.
Adding the emulator added about 12mm of preload so I cut it off the spring and made a spring holder that added about 4mm of preload. Sag with the new forks came out to about 36mm.
Only about 40 miles on the bike, the front end feels good. Still need to get some Ikons.
Offline SKTP
Re: Emulators
« Reply #15 on: November 06, 2019, 08:52:22 AM »
Race tech did my forks. It was expensive and every time I called they acted like I was really bothering them. I did not think they had very good customer service at all. My forks feel fine. They squeak if I hit a driveway slope at low speed. They are definitely better than they were (stock untouched for 30-40 years) but they are nothing to write home about...
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
