Author Topic: front sprocket on my 78 750A  (Read 1539 times)
Offline Bazzer
« on: October 11, 2019, 03:33:30 PM »
The front sprocket on my 78 cb750A  which is 15t  630 pitch, is no longer available with the two 6mm threaded holes for the locking plate. The one that is available has no threaded holes and is kept on with a circlip. Does anybody know were i can get the circlip.
Online jgger
Re: front sprocket on my 78 750A
« Reply #1 on: October 11, 2019, 10:01:02 PM »
What keeps the sprocket from sliding in against the motor ?
I would think that whoever  is selling the sprocket would also have the clip. I see you are in the UK, perhaps David Silver Spares (DSS).
Offline Bazzer
« Reply #2 on: October 12, 2019, 04:03:00 AM »
Thanks for the reply. The shaft splines stop just before the shaft oil seal, so the sprocket is kept from touching the inside of the engine. I was up until the early hours searching ebay and then i found what i needed. Just need to measure the place on the shaft were the clip goes so i can order the correct clip.
        All the best
        Baz.
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
« Reply #3 on: October 12, 2019, 08:31:10 AM »
Are you sure its not available?  Maybe you mean - not from Honda?
https://4into1.com/parts-unlimited-front-sprocket-630-15t-honda-cb750-1977-1978/
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline Bazzer
« Reply #4 on: October 12, 2019, 09:40:05 AM »
Just got your message, and it looks promising, I will check it out. Thanks.
Offline Bazzer
« Reply #5 on: October 12, 2019, 10:08:41 AM »
Have just ordered the sprocket from parts unlimited. I had asked DSS last week, and they said it's no longer available, also searched the CMS web site they said the same. Thanks again, will let you know how i get on.
Offline Bazzer
« Reply #6 on: October 16, 2019, 06:33:42 AM »
Got the sprocket today, all the way from the USA, so quick. It's now on the bike. Thanks again.
