Author Topic: Linkage gaskets  (Read 633 times)
Offline britman
Linkage gaskets
« on: October 16, 2019, 08:54:53 am »
Doing a rebuild on some real nasty CB500 Four carbs.  A lot PB Blaster soaking has gotten everything down and disassembled. The linkage gaskets however are in pretty bad shape.  I can't seem to see where there are any replacements are available, so I am thinking of using some thin rubber washers on at least one carb as a replacement.  Thoughts or ideas anyone.....
Offline Scott S
Re: Linkage gaskets
« Reply #1 on: October 16, 2019, 10:51:28 am »
 This has been covered recently.  They're not absolutely necessary and serve as dust shields. People have made new ones from a bicycle inner tube or similar.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline britman
Re: Linkage gaskets
« Reply #2 on: October 16, 2019, 11:09:44 am »
Thank you Scott, I did a search but must not have put in the right inquiry.  Very much appreciated.  Going to live without the little buggers.......
Offline pjlogue
Re: Linkage gaskets
« Reply #3 on: October 16, 2019, 11:19:12 am »
You can get silicone rubber sheets off the internet.  I think you could make replacements fairly easily and the silicone would last forever.
-P.
Offline britman
Re: Linkage gaskets
« Reply #4 on: October 16, 2019, 11:33:12 am »
The rebuild video's I have seen on Youtube appear to put things back up without them, so they are off the menu.  I did find someone had been in the carbs prior to me, three plastic floats and one foam.  It is hard to believe as dirty as the carbs were, but I also realize the bike has not been run since 1994 apparently.  Guess I am lucky the rust was at a minimum.....
« Last Edit: October 16, 2019, 12:38:16 pm by britman »
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
Re: Linkage gaskets
« Reply #5 on: October 18, 2019, 03:42:09 am »
Just been through the same thing.
You can get replacements (used) here: https://www.400fourbits.co.uk/#fuel
Or email Steve at spares@400fourbits.co.uk
He charged me £8 for two
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
