Author Topic: Stripped carb bowls  (Read 968 times)
Offline Ace Blackwell
  • 1977 CB550F - Resurrection in progress
Stripped carb bowls
« on: October 16, 2019, 12:24:51 pm »
All,
I have two of my four carb bowls with stripped drain holes.  I’m going to have to tap and go with a bigger size bolt/screw.  Is there a best practice among other owners or just go with what ever size and pitch works?
Thanks
Ace
1977 CB550F Work in Progress
Offline BenelliSEI
  • 1969 cb750
Re: Stripped carb bowls
« Reply #1 on: October 16, 2019, 01:40:12 pm »
Ace...... i’ve tried this a few times and not had much luck. I’ll be curious what others suggest. I usually plug them with a wad of epoxy and then clean up another bowl from my spares. I’ve collected a few over the years (from some really terrible barn finds that ended up becoming Parts Bikes).
Offline Moleskins
« Reply #2 on: October 16, 2019, 02:03:45 pm »
I’d try not drilling out but re tapping with a finer thread. Use an o ring and don’t over tighten.
« Reply #3 on: October 16, 2019, 03:38:05 pm »
Personally, I wouldnt waste my time trying to repair, I would find replacements.
The big question is how did they get stripped?!
Offline pjlogue
« Reply #4 on: October 16, 2019, 03:55:21 pm »
Your best bet as Steve-0 said, find replacements.  If that proves hard to find I would fill the holes with J-B weld, re drill and tap after very carefully cleaning the stripped hole so no oil/contaminants are on the metal.  Another option is get Helicoils, cut them to length, insert with J-B Weld and clean up the threads after the epoxy sets up a bit so you have a clean thread.  You woulld need to make sure the Helicoil is in far enough so the O ring that seals the plug has a place to seat against the bowl.
-P.
« Reply #5 on: October 16, 2019, 05:15:45 pm »
Thanks all. Does anyone know the thread on the drain screws. I took to Lowe’s but it didn’t match any of the standard threads like M6 x 1.0
Offline jaytee-nz
« Reply #6 on: October 16, 2019, 05:49:06 pm »
Don't know for sure but most Honda "fine" threads tend to be 1.25 pitch.
« Reply #7 on: October 16, 2019, 05:57:05 pm »
Thanks for all the info guys.
Offline Keith
« Reply #8 on: October 16, 2019, 06:30:24 pm »
Used ones on eBay?
« Reply #9 on: October 17, 2019, 06:39:26 pm »
Most of the PD-style carbs with stripped threads can be fixed up by using longer screws. There are usually 3 or 4 more threads above the stripped part. I think the pitch is 0.8mm.
Offline 6adan
« Reply #10 on: October 18, 2019, 06:11:13 am »
  I have used time-serts on several GL1000 carbs. That way you can use the same screw as stock. You do have to get a kit for each size screw that you need to repair.  To me much better than Helicoils.
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
« Reply #11 on: October 18, 2019, 09:33:24 am »
Thank all,
I looked up both time-serts and Helicoils.  This are inserts or sleeves right?  I'll check in to it further.  It would allow me to use current brass screws as you guys mentioned.  Or I could just tap out and go with a little bigger screw. It wouldn't be original but might be functional.   Could move altered bowls to 2-3 and leave 1-4 with original screws.  Wouldn't be as noticeable to the average person.
In truth I lost the original screws years back (80s)and being young and broke, I found bolts at home that were same size but must have been different pitch.  They damaged the threads to the point that the original brass (or new aftermarket I just bought) will not tighten down.  I was hoping against the odds that there was a trick to getting them to work again lol.
Thanks again
