Author Topic: Engine exterior restoration advice.  (Read 1051 times)
Offline Jake750
« on: October 18, 2019, 09:46:09 AM »
978 750f. Barn find. engine currently separated from frame and on a stand.
Engine exterior is pretty corroded. The 78 750f engines came out of the factory with a black coat of paint on them. I'm sure it looked good in it's prime but right now its just a corroded mess with paint flaking off all over. Don't even get me started on the engine fins.
I started removing the paint/corrosion with fine grit sand paper. Seems to be working well bit is slow. I have a wire paint stripper drill attachment but am afraid it might be too abrasive.
Anyone have any good advice/tips/techniques for cleaning and restoring a corroded engine that are realistic for someone working in their garage?
Ideally I'd like to just strip all the paint off and polish up the base metal, similar to how to earlier K model engines looked. giving it a coat of black heat paint is my plan B if polishing the metal isn't realistic.
Thanks!
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Engine exterior restoration advice.
« Reply #1 on: October 18, 2019, 10:46:15 AM »
Try paint remover.
You could make a soda blasting setup for better results.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline tlbranth
« Reply #2 on: October 18, 2019, 11:15:57 AM »
I just did my '75 GL1000 engine. I put it on an engine stand, blocked all holes and sandblasted it outdoors. What I've found works really well is Home Depot's Silica Sand. It's nicely graded and has good cutting edges. First mask the covers you want to refinish smooth. After blasting, take masking tape off covers and blast with soda. Costco has decent sized bags of the stuff.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Jake750
« Reply #3 on: October 18, 2019, 12:08:21 PM »
tlbranth that thing is beautiful. What brand paint did you use if you don't mind me asking?
So to be clear, you used the silica sand on everything besides the covers, then used soda on the covers??
« Last Edit: October 18, 2019, 12:13:01 PM by Jake750 »
Offline maxheadflow
« Reply #4 on: October 18, 2019, 07:38:07 PM »
Excellent Info..
Offline Doobie
« Reply #5 on: October 19, 2019, 02:56:09 AM »
Cool bike!
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
Online beemerbum
« Reply #6 on: October 19, 2019, 08:27:33 AM »
Outstanding motorcycle! Totally unique treatment of a "Wing"
Offline tlbranth
« Reply #7 on: October 19, 2019, 10:50:53 AM »
Actually, I blasted everything with sand. But my covers are painted. If you want smooth, natural finish covers I think you might want to soda blast them to keep them smooth. If you do sandblast, you want to make sure to have really good sealing over holes to the inside of the engine. I've soda blasted some stuff on my CB750 before and it works quite well but it gets pricey and the soda seems to kill the grass. Best if you use a blast box to recover the stuff.
All the green parts (engine and tin) were painted with the same paint:  https://tcpglobal.com/collections/hot-rod-flatz-paint-Olive-Drab-Green
Primer was an epoxy from Wesco.
My engine is water cooled and I'm not sure the paint would work on the higher temp CB head & block.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
