Author Topic: cb400f rear wheel distance collar  (Read 909 times)
Offline timbo
« on: October 28, 2019, 07:24:12 AM »
Hello,
I am missing the rear distance collar on my CB400F. Honda nr 42625-286-000
This seems like a simple piece to make on the lathe.
Does somebody have a collar and be willing to take some mesurements for me?
Tim
Re: cb400f rear wheel distance collar
« Reply #1 on: October 28, 2019, 08:37:14 AM »
That number is orriginally a cb 450 part so should be lots about
Offline timbo
« Reply #2 on: October 28, 2019, 08:52:50 AM »
I know but an original new one is 30 euro plus extra shipping.
15 minutes on the lathe and I have one,but it would be easy if i have the dimensions.
Offline awrawr
« Reply #3 on: October 28, 2019, 11:34:09 AM »
I have a loose one in the shed. I will see if I can lay hands on it ..... watch this space......
Offline awrawr
« Reply #4 on: October 28, 2019, 12:03:26 PM »
Internal diameter 17mm
External diameter 30mm
Length 33.5mm
But now I'm not sure if this is the right bit....(might be the spacer) . I'll have another look.....
« Last Edit: October 28, 2019, 12:10:07 PM by awrawr »
Offline awrawr
« Reply #5 on: October 28, 2019, 12:53:23 PM »
No, sorry that was the spacer. I can't find the collar right now. I'll have another look tomorrow.
Offline Tim2005
« Reply #6 on: October 28, 2019, 01:34:22 PM »
which side is this one, sprocket side or brake plate side?
Offline timbo
« Reply #7 on: October 28, 2019, 02:12:23 PM »
hey,its sprocket side
Offline Bodi
« Reply #8 on: October 28, 2019, 04:11:52 PM »
Outer 30mm
Inner 17.1mm
Length 29.75mm
Offline timbo
« Reply #9 on: October 31, 2019, 02:43:36 AM »
thanks!!!
Offline timbo
« Reply #10 on: December 13, 2019, 02:10:30 AM »
Hello,
There is been some confusion on the part I need the dimensions of.
It is the collar spacer that is fitted in the hub between the long spacer tube and the sprocket side
bearing. I think it goes in the bearing.
regards
tim
Offline Bodi
« Reply #11 on: December 13, 2019, 08:28:39 AM »
Dang. Didn't know that was the official name for the part, seems more like a bore adapter to me.
length overall:  17.8mm
flange thickness:  4mm
outer diameter to fit 20mm 6304 bearing , measures pretty much 20mm
inner bore to fit 17mm axle measures about 17.05mm
Flange diameter - forgot to measure and not willing to go out in the snow again. Doesn't much matter... looks like it sticks out a bit more than the flange width so say 5mm... making the flange diameter ~ 28mm?
« Last Edit: December 13, 2019, 08:32:57 AM by Bodi »
Offline timbo
« Reply #12 on: December 13, 2019, 10:07:21 AM »
thank you!!!!!
I made it today and the messurements where spot on!!
regards
Tim
