Author Topic: 1976 750K Battery Cables???  (Read 502 times)
Offline jmelche2
  • 1974 CB750K
« on: November 10, 2019, 07:04:47 AM »
Somebody along the way has butchered these cables and I would like to get them back as close as possible to original.  I have found what I think is the correct positive cable on Vintage750.com.  Not sure about the negative but hoping you may be able to provide the length and a photo of a properly grounded cable.  I think it mounts under the motor mount bolt circled in red below.  Here is the link to the Vintgage 750 cables I am thinking about purchasing:
https://www.vintagecb750.com/products/5/electrical/116/battery-fuse-relay
« Last Edit: November 10, 2019, 07:06:48 AM by jmelche2 »
Online BenelliSEI
  • 1969 cb750
Re: 1976 750K Battery Cables???
« Reply #1 on: November 10, 2019, 08:45:40 AM »
The ground cable goes where you circled, between the engine case and the frame. Not easy, but tidiest (and original) installation. Either cable will do, but I think the later style is too long. Measure your bike and decide......
