Author Topic: CB750 Engine Table  (Read 1875 times)
Offline Dolomite
  • I'm 40% Dolomite.
CB750 Engine Table
« on: November 14, 2019, 02:59:26 PM »
At the risk of being accused of sacrilege, the case was shot. The number 4 rod dropped the connector and bent the rod and gouged the crank channels. This is the 2nd motor table I've made (first was a 4.2V8 table) and thought I'd share. I used a TC bros motor stand as the base since I already had one and just lined the bottom with nonslip fabric for table and chair legs. I degreased and cleaned the engine as much as possible using a power washer, without getting in there with a wire brush or anything because it won't be subject to outdoor use. Once everything was bolted together it was given a healthy dose of rustoleum self etching primer and given a full 24 hours after the final coat to dry. Then rustoleum high performance enamel stainless spray paint was costed on liberally over several days to try and fill in as many rough spots and defects as possible. After drying for 24 hours it was coated in clear coat enamel. The valve cover will be given glass table bumpers for the top to sit on for the front of the motor. The rear support I disassembled 2 of the pistons from their conrods and attached them to the other set upside down as shown in the photo. They're mounted to the the rear upper motor mounts with a threaded rod. I cut the two removed wrist pins down to the width of the conrod making a perfect spacer. I did end up notching the back side of the piston heads to give them enough room to sit level to support the glass. Glass will be arriving next week, 18x26 to cover the base perfectly with a little overhang. Once the glass arrives and I can set it level and proper I will be torquing the rod down completely with some nord lock washers so they don't slip under the weight.
I already had the paint and the stand so total cost was about $10 in hardware (to join the two conrods and the nord washers)
Offline Dolomite
  • I'm 40% Dolomite.
Re: CB750 Engine Table
« Reply #1 on: November 14, 2019, 03:04:29 PM »
Another photo with supports.
Offline kerryb
  • Not a very
« Reply #2 on: November 14, 2019, 06:53:13 PM »
That's cool...and a sneaky way of having a bike in the living room.
Offline Dolomite
  • I'm 40% Dolomite.
« Reply #3 on: November 14, 2019, 07:00:47 PM »
The V8 coffee table incase anyone was interested in seeing the layout difference.
Offline Just John
  • Apparently I am a glutton for punishment
« Reply #4 on: November 14, 2019, 11:25:23 PM »
Very nice! I'm preparing to do about the same with the remains of a CB77 motor.
John
Member
AMA Charter Life Member
AMCA
VJMCA
Offline K7-Steppy
« Reply #5 on: November 15, 2019, 07:43:15 AM »
That is so cool!
Sent from my Pixel 3 XL using Tapatalk
Offline Dolomite
  • I'm 40% Dolomite.
« Reply #6 on: November 15, 2019, 08:42:14 AM »
I don't have anyone to tell me no, hence also having a V8 table. Also going to be turning the crank into a lamp, and working on using an array of gears from the motor to make a clock that will rotate the gears.
Offline Dolomite
  • I'm 40% Dolomite.
« Reply #7 on: November 17, 2019, 05:41:25 PM »
Glass arrived today. Did a mock up, just waiting on some nordlock washers so that once the piston supports are torqued down they won't  slide under weight.
« Reply #8 on: November 17, 2019, 07:21:10 PM »
so cool...well done
Offline slikwilli420
  • Master of Disaster
« Reply #9 on: November 18, 2019, 08:42:05 AM »
Very cool table. Giving me some inspiration to do one myself. Interesting to see where the case numbers are relative to where I usually see them.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #10 on: November 18, 2019, 08:49:57 AM »
What is the engine number?
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #11 on: November 18, 2019, 10:28:12 AM »
I like it a lot! :)
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
