Author Topic: 78 750 brake upgrade suggestions  (Read 932 times)
Offline Jnel
« on: November 16, 2019, 08:59:34 AM »
I dumped a bunch of time and money into this build.  I don't want to skimp on the breaks.  So has anyone got some thoughts on a modern brake system.    I'm in for all new brake lines, no problem.  But would really like a multi piston set up that is a proven bolt on for my stock forks. Is there a good source out there for 750's?
Thanks,  John
Sent from my SM-N950U using Tapatalk
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: 78 750 brake upgrade suggestions
« Reply #1 on: November 16, 2019, 09:10:32 AM »
Just put dual drilled discs on, they work great.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #2 on: November 16, 2019, 09:41:05 AM »
K or F? Edit: I see you have an F. ;D
http://forums.sohc4.net/index.php/topic,89771.0.html
« Last Edit: November 16, 2019, 09:50:49 AM by scottly »
Offline Jnel
« Reply #3 on: November 16, 2019, 11:16:18 AM »
Scottly... thats good info.  But honestly,  i don't want to source out used stuff.  I want to go buy new stuff that bolts right on.  BRMBRO or similar quality.   Ther has to be someone out there that makes this aftermarket upgrade kit?
« Reply #4 on: November 16, 2019, 01:11:51 PM »
Not to my knowledge, you have to remeber the "newest" 750 is over 40 years old so not worth modern manufacturers working on
« Reply #5 on: November 16, 2019, 04:38:45 PM »
unfortunately, I believe bryanj is correct.  And Scottly has given you the best bolt on upgrade.  Try a more modern master cylinder too.  In my opinion, the stock sohc4 masters are the worst part.  Basically, anything from the late 80's on up is a huge improvement.
« Reply #6 on: November 16, 2019, 06:26:46 PM »
John, the opposed piston Brembo calipers won't work with the stock forks; they are too thick on the inside, and will hit the "spokes" of your comstar wheel.
Make sure you use the 32mm caliper used on the V65, and you will not be disappointed. ;)
Sean, Honda used a huge MC on the F2/3, with only dual 38mm calipers, which is where they #$%*ed up, IMHO. ;) The stock late F MC should work well with two 32mm twin piston calipers..
« Reply #7 on: November 16, 2019, 10:10:53 PM »
http://www.beringer-brakes.com/moto/technologies/gamme-classic-30.htm
Might be a good idea to improve the engine power so there is a reason for much better brakes.
« Reply #8 on: November 17, 2019, 12:12:16 AM »
yeah PeWe, I thought about mentioning that Beringer stuff, as sohc4 Cafe Racer Fan has a set of those on his 550.  I think he was lucky enough to get them for free...that is really lucky as a complete dual disc set up with master cylinder is gonna cost about $1800.  Of course, you could piece something together using some oem components, but one dual piston caliper costs $450.  It looks like extreme high quality top notch stuff, but for that kind of money there should be a huge braking improvement.
« Reply #9 on: November 17, 2019, 02:09:05 AM »
On Red I have K3 MC and it has no problems working with F3 brakes.
Jnel you might look into GW fork swap.
« Reply #10 on: November 17, 2019, 04:44:26 AM »
My CB750 K6 has only 2 x stock brakes with DSS rotors and DSS MC. Work fine, much better than stock.
I have tested a quick stop in over 160 kmh, I heard the tire against the asphalt.
Offline 1976cb750f836
  • 76 cb750f, 836, 78 wheels
« Reply #11 on: November 17, 2019, 06:03:39 AM »
I have 78 F front end, I drilled my rotars and added an 81 gs750 master. BIG improvement!  It's benn a while, but the stock master is something like 17mm, the gs is like 14mm, way better feel, way less finger effort on lever. I used a eBay China copy, about 35$. Also works on 1st gen goldwing.
Offline Dolomite
  • I'm 40% Dolomite.
« Reply #12 on: November 20, 2019, 07:37:55 PM »
If you can get a hold of pre k7 750F forks, the 79+ DOHC calipers should bolt right up.
