Author Topic: CB750F2 cafe racer rebuild  (Read 6913 times)
Offline NalydStrea
Re: CB750F2 cafe racer rebuild
« Reply #50 on: September 18, 2020, 12:57:17 PM »
Today I mounted all the side covers, except for the alternator cover.
I'm missing washer #6 in the picture, part number 28109300000.
Also it's not available anymore at CMSNL.
I'm 100% sure it wasn't there before, because I put everything in bags and labeled them.
Can I use other washers for this as it's "only for the starter motor"?
Anyone has the dimensions of this washer?
« Reply #51 on: September 18, 2020, 03:41:20 PM »
those get lost a lot as when you remove your stator cover, they will often stay in the cover, only to fall out unnoticed later.
« Reply #52 on: September 18, 2020, 04:22:43 PM »
If you like bead blasting, vapor blasting will blow your mind on other more delicate parts and finishes.
Offline NalydStrea
« Reply #53 on: September 19, 2020, 08:07:05 AM »
I've read a lot about it.
You also don't need to worry about getting glass beads in your engine, which is a great thing.
Offline NalydStrea
« Reply #54 on: September 19, 2020, 08:08:18 AM »
I'm sure it wasn't there, because I always double check those things.
Probably long lost by any of the previous owners.
Offline NalydStrea
« Reply #55 on: September 19, 2020, 10:23:29 AM »
Found the dimensions on this forum:
Here's the measurements:
OD = 39.8mm (1.568 in)
ID = 12.2mm (0.481 in)
Thickness = 1.0mm (0.0394 in)*
mystic_1
I can laser cut it out of 1mm steel at work, but I think it's supposed to be a hardened steel washer...
Offline Phil K
« Reply #56 on: January 15, 2021, 02:30:44 AM »
Did you manage to manufacture this part?
I am in the same situation but measuring the free play The disc could be 2mm to 2.5mm
What were your findings? ( and did you make a spare)??
Phil
Offline NalydStrea
« Reply #57 on: January 21, 2021, 05:34:50 AM »
Phil
Yes, I laser cut it out of 1mm thick stainless steel.
But the engine is still out of the bike, so I don't have any findings yet  ;D
Offline NalydStrea
« Reply #58 on: July 15, 2021, 02:08:31 PM »
Long time no see again, as I don't have much (or any) time to work on the bike.
Meanwhile I worked on the frame to fit the seat that I 3D-printed.
I also installed my self-made frame split kit.
Also I ordered some oversize (61.25mm) pistons from CMS that I will balance tomorrow.
A larger update will come soon.
