Author Topic: Brake Piston Won't Retract, Tried Everything  (Read 2671 times)
Re: Brake Piston Won't Retract, Tried Everything
« Reply #25 on: November 20, 2019, 08:18:20 AM »
As long as you easily can push your bike without a braking wheel, everything is just fine. Sound of squealing pads is normal now and then. Especially in low speed entering a cafe area :)
Offline vik351
  • Adelaide South Australia ...
« Reply #26 on: November 20, 2019, 02:20:59 PM »
The pads in one of mine are slotted ...??? and the others are what I call normal ( Have two Hondamatics)
The slotted ones squeal like buggery with just the right touch of the lever, squish it a bit more and they dont.
I actually like it in traffic as you can see the blind drivers look in their rear view mirrors, WTF is that behind me makin the racket, at least then they know you are there, I dont have loud zorst pipes  :-\
vik... my two Bob's anyway...
Offline disco
« Reply #27 on: November 20, 2019, 09:30:37 PM »
You may have swapped the stationary pad with the piston pad when you put it back together.
Is that even possible with the pin that sticks out back of the stationary pad?
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
« Reply #28 on: November 20, 2019, 11:50:07 PM »
No pin on the 500
Offline 1976cb750f836
  • 76 cb750f, 836, 78 wheels
« Reply #29 on: November 21, 2019, 05:00:39 AM »
The new piston and seal might have too much friction, too tight? Did u clean the seal grove really well, did u clean the piston bore well, with scotchbrite and brake fluid? Was the new piston a polished finish?
Offline tlbranth
« Reply #30 on: November 21, 2019, 05:40:52 PM »
If the rotor is cool, so are you. No issue.
That says it. Disc brakes always rub a little. It's their nature. You said the wheel spins 2 revs before it stops. That sounds more-or-less normal to me. It sounds like you adjusted the thing correctly. Just ride the bastard. You're OK.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Online Don R
« Reply #31 on: November 21, 2019, 10:41:34 PM »
 As my drag racing friends say, just send it. Meaning in this case, ride.
