Author Topic: 1979 CM400A Air Cut-Off Valve  (Read 887 times)
Offline Maraakate
« on: November 18, 2019, 04:16:08 PM »
Ideally I'd like to make the subject CM400A/T/C/E because I believe this applies to all of them (may even be the same part).  I finally got everything buttoned up on my CM400A except there is a small air leak from the Air Cut-Off Valve cover.  Specifically, it is the o-ring.  It's shrunk and flat.  I verified the "pumping noise" went away by holding my thumb tightly over the hole with the cover off and the bike running.  Otherwise, I get a pumping noise that's an obvious air leak, and at higher speeds (above 30mph) if I let off the throttle you can hear this obnoxious high pitched pumping sound.
I'm sure someone knows the o-ring size, but I am wondering if anyone has used the kit from 4into1?  The diaphragm itself on the valve is kind of "eh" so I probably should just replace it now that I've disturbed it.
1977 CB550K
1979 CM400A
Offline becken
Re: 1979 CM400A Air Cut-Off Valve
« Reply #1 on: November 23, 2019, 06:39:15 AM »
Have you checked the Honda Twins Forum? Lots of good information there.
https://www.hondatwins.net/forums/forum.php
1976 CB550F bought new
1981 CM400A wife bought new
2004 GL1800
