Author Topic: Sealant between valve body and lower case?  (Read 1203 times)
Offline sammon287
« on: November 19, 2019, 04:01:54 PM »
  Since there is no gasket, is there a need for sealant between the valve body (oil passage body) and lower case? Also between the regulator valve and the oil passage body? I think not, but it has been a long time since I took it all apart. The service manual doesn't mention it, but some best practices aren't in the books. Page 9-4 is the area I'm referring to. http://manuals.sohc4.net/cb750a/service_manual/SM750A_4.pdf
1976 CB750A
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
Re: Sealant between valve body and lower case?
« Reply #1 on: November 20, 2019, 07:50:46 AM »
I do not use sealant when assembling.
When disassembling, I've never noted any residue indicating a sealant had been used previously.
The same is true when I had done Ford valve body work - no gaskets or sealant.
Just need absolutely clean mating surfaces.
My 2 cents.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline sammon287
« Reply #2 on: November 20, 2019, 10:29:42 AM »
My 2 cents.
Great. Thank you for confirming what I suspected. I just wanted acknowledgement from anyone who has reassembled an "A" engine and had it work afterward.
1976 CB750A
