Author Topic: Clutch Plates  (Read 1301 times)
Offline KilledByGreg
Clutch Plates
« on: November 21, 2019, 07:36:02 PM »
Last weekend my clutch blew out while I was on a ride, so I took it apart once I pushed myself home. Once I got my clutch disassembled, I noticed that one of the steel plates was much thicker, and was a different style than the rest. Has anyone else ever seen this? Because I can't find anything regarding this odd plate (not even in Hondaman's book). It seems like all of the friction plates that were behind it (towards the engine) were destroyed and left with a thickness around 2.65mm, while the friction disks ahead of the odd plate were in spec. Here are some photos:
Online bryanj
Re: Clutch Plates
« Reply #1 on: November 21, 2019, 08:16:28 PM »
Standard item in later clutches to try and stop rattle, should be explained in one of the bulletins in technical section
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Clutch Plates
« Reply #2 on: November 22, 2019, 04:30:59 AM »
What year? The later clutches had the thicker steel plate as original equipment while some early models had this updated as a service bulletin. The inner frictions wear out first. Scuff the steel disks with a scotchbrite pad, put new friction disks in and keep riding.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline maxheadflow
Re: Clutch Plates
« Reply #3 on: November 22, 2019, 08:13:45 AM »
That steel plate has small spring pieces between the plates that allow the plate to squash down under pressure. It preloads the clutch pack slightly to provide a wider friction zone.  These were used on HD EVO clutches to increase the friction zone.   Make sure the rivets are still tight. they can rattle apart.  They typically go somewhere in the middle of the stack.
Re: Clutch Plates
« Reply #4 on: November 22, 2019, 10:33:44 AM »
K5
Re: Clutch Plates
« Reply #5 on: November 22, 2019, 10:34:21 AM »
Thanks! I’ll check there!
Re: Clutch Plates
« Reply #6 on: November 22, 2019, 10:36:15 AM »
Thanks, rivers still seem right, but I’m confused as to where they go in the mix. I suppose I’ll stick it back in the same position.
Re: Clutch Plates
« Reply #7 on: November 22, 2019, 04:04:58 PM »
It's an anti-rattle plate, and can pretty much go anywhere in the stack, although they're usually located in the middle. Be careful cleaning your steels if you decide to clean them mechanically, I took one in the face a week or so ago, and needed plastic surgery last Tuesday to repair the damage. Make sure the steels aren't warped (use a sheet of glass) and that they're all going the same way. If you feel each steel plate, you'll notice that each has a "sharp" edge, and a "smooth" edge. Make sure all the "sharp" edges are pointing in the one direction. ;D
Re: Clutch Plates
« Reply #8 on: November 22, 2019, 06:10:55 PM »
In OEM engines of the 750K5 era, the dual-steel sprung plates was the 3rd steel plate from the back. In the later K6/F0 (and onward) engines they were most often the second steel one in the stack, where the top cork plate has wider outer tabs than the other plates in the pack.
