Author Topic: Front axle spacers on GL forks.  (Read 777 times)
« on: November 24, 2019, 11:01:49 AM »
We mounted an early GL fork on a 750. Front hub is same part number.
A few days back I measured for spacers and we did not have a Speedo drive in there. Don't plan on running it.
So GL axle and nut, i think nut was on left side, and it looked like i needed about 1/8 spacer on left side. Now I am wondering if GL used a longer spacer ?
 The other side was tough to measure but I came up with .94.
 So My kid got spacers made at .12 and .94 and he says nothing fits. ...?
 So I will go look today and if one side fits Then I can figure out the other. Anyone know if GL uses a different length spacer on the non Speedo side, and is the nut for axle on  left side.
Re: Front axle spacers on GL forks.
« Reply #1 on: November 24, 2019, 01:38:42 PM »
If you dont get an answer before i will look in my GL 1000 manual for position of nut in the next couple of days.
« Reply #2 on: November 24, 2019, 01:43:17 PM »
I will look at it in the next few hrs, I can't see that I was way out, I have measured up dozens of bikes for spacers.
 If one size fits right and centre's the wheel it gets easier.
« Reply #3 on: November 24, 2019, 01:44:40 PM »
Just looked on cmsnl and it shows the nut on speedo drive side and the spacer on opposite side has a 300 middle number so 750 part. Hope that helps
