Support the site. Your contributions keep this site running.
Quote from: lash on November 27, 2019, 05:56:43 PMNot sure what you mean about bigger base gasket and grind away?The "Blue Ridge Mountain engineer" method of boring each cylinder hole in your top case is to put the oversize base gasket in place, mark the cases tracing the bigger holes, remove the gasket and get stuck into it with a die grinder or dremel tool, File, Bowie Knife, or whatever cutting instrument you have available, usually conducted while drinking moonshine and wearing Dickies overalls and a straw hat.
