Author Topic: 750 K0 first start, HAS oil pressure  (Read 2511 times)
Offline Tews19
  • I am no
« on: November 29, 2019, 01:17:00 PM »
After almost 1 year I heard my motor run after a complete rebuild. She idles high as hell but still runs. I pulled the tappet covers and the top end looks dry. I did prime the engine but to no avail, no oil on the top end.
Any suggestions?
« Last Edit: November 30, 2019, 09:17:51 AM by Tews19 »
1970 Honda CB750 survivor.
Offline kerryb
  • Not a very
Re: 750 K0 first start
« Reply #1 on: November 29, 2019, 01:49:52 PM »
Did you pull the pump and prime it separatley? I had to do that once, but it was on a k-8.  It did make the difference though.
p.s. congrats on the first start.
Offline Tews19
  • I am no
« Reply #2 on: November 29, 2019, 01:59:06 PM »
I swapped in new o rings on the oil pump. I guess I'll look into pulling the pump to see if that's the issue.
« Reply #3 on: November 29, 2019, 02:49:11 PM »
nick, did the oil pressure light go out?  Did you have a pressure gauge hooked up?  How long did you let it run?
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: November 29, 2019, 02:58:10 PM »
Had the same problem with my K0. Drop the pan and pump, prime it and it will come up.
Offline Tews19
  • I am no
« Reply #5 on: November 29, 2019, 03:15:10 PM »
The light has gone off. Before starting it was on. I can't have it run long as I need to lower the idle. It's around 5k at the moment. Pressure gauge? Not sure what you mean?
Offline Tews19
  • I am no
« Reply #6 on: November 29, 2019, 03:15:49 PM »
Sounds dumb, if I drop the pan, how do I prime it?
« Reply #7 on: November 29, 2019, 03:38:03 PM »
Are you using an oil pressure gauge on the oil galley by the points to show actual pressure vs just the dummy light?
Drain the oil from the pan (if there is oil in it!), drop the oil pan and remove the pump. Soak it in oil covering the screen, turn the gear to burp out air and reinstall making sure you have the O-rings in place. Pour 2 quarts down the drain holes in the head behind the caps in the valve cover to get plenty of oil into the pan.
Offline bhudders
« Reply #8 on: November 29, 2019, 03:44:16 PM »
Couldn’t find a nice place to dump this decided to share it with my CB750 SOHC buddies it’s not long
Oh What A Pleasurable
Offline Tews19
  • I am no
« Reply #9 on: November 29, 2019, 04:29:09 PM »
Only the dummy light Jerry. Someone recommended that I use a pressure gauge where you suggested as well.
I did remove all tappet covers. I used a syringe and squited 10mm of oil in each tappet.
« Reply #10 on: November 29, 2019, 05:21:09 PM »
sooo, sounds like you probably have pressure which means there is nothing wrong with the pump.  Question is why would the top end still be dry?  Oil jets under the cam tower double, triple checked free and clear and assembled correctly with all 4 o-rings?  Did you use plenty of assembly lube on cam and rocker assembly?  Also, we really need to think about qantifying how long the bike ran with the valve train dry.  In seconds?  In minutes?  Was there excessive noise?  If you pushed the button, it fired quickly, shot to 5000rpm, and you shut it right off, quite possible oil has just not reached the cam.
« Reply #11 on: November 29, 2019, 05:23:57 PM »
Make sure you have fixed your idle and thought about some of these questions before starting again.
Offline Tews19
  • I am no
« Reply #12 on: November 29, 2019, 06:25:48 PM »
I'll tackle the idle tomorrow. I got ahead of myself and the high idle was due to vacuum leak. I didn't tighten down the clamps earlier today. Now i tightened them and the idle is around 3k now. I can stnc the carbs but will need to set the timing first. I pulled the plug by the points cover,  oil poured out. The oil was cold though as the bike only ran for about 45 seconds.
Baby steps for now but I have time.
Offline Scott S
« Reply #13 on: November 30, 2019, 03:25:55 AM »
 Should go here: http://forums.sohc4.net/index.php/topic,109172.0.html
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #14 on: November 30, 2019, 06:43:17 AM »
 You can tell a lot by looking in the oil tank while running also. There will be circulation and bubbles quickly if all is well.
Offline Tews19
  • I am no
« Reply #15 on: November 30, 2019, 06:56:07 AM »
Thanks Eric.
Offline Tews19
  • I am no
« Reply #16 on: November 30, 2019, 09:17:26 AM »
She has oil pressure!!!!!!. Took a while I think the amount of running time kept being cut short due to my own insecurity of not knowing the how the engine would be after a rebuild. This is my first 750 engine build literally from the cases up so I'm pretty happy with the result. No oil leaks. I do need to sync the carbs while I wait for the gauges to come in.
Offline Tews19
  • I am no
« Reply #17 on: November 30, 2019, 09:18:31 AM »
She has oil pressure!!!!!!. Took a while I think due to the amount of running time kept being cut short due to my own insecurity of not knowing the how the engine would be after a rebuild. This is my first 750 engine build literally from the cases up so I'm pretty happy with the result. No oil leaks. I do need to sync the carbs while I wait for the gauges to come in.
Offline Deltarider
Re: 750 K0 first start, HAS oil pressure
« Reply #18 on: November 30, 2019, 09:42:10 AM »
Don't fixate on pressure! You want to have that oil up there at the cam. You can have oil pressure WITHOUT  oil arriving at the cam!!!
CB500K2-ED Excel black
Offline Tews19
  • I am no
« Reply #19 on: November 30, 2019, 09:43:44 AM »
Ok, I should have expressed I have pressure on the cam and all the tappets are covered in oil.
« Reply #20 on: November 30, 2019, 10:46:38 AM »
 Congrats, now you can enjoy tuning it.
