Author Topic: Blowing a fuse once hitting 60  (Read 1899 times)
Offline JBend
« on: December 01, 2019, 09:32:25 AM »
This has seemed to have happened twice now. New wiring harness, just installed Rick's regulator/rectifier not sure what's going on. 1977 cb750f
Re: Blowing a fuse once hitting 60
« Reply #1 on: December 01, 2019, 07:53:56 PM »
What kind of fuse are you using, and is it in the old OEM fuse clip holder?
Offline Tomshep
« Reply #2 on: December 24, 2019, 11:47:19 AM »
That looks not so much like sixty as the point where the voltage regulator is supposed to reduce the current to the  field coil in the alternator. I reckon that when the the contact moves, it shorts the supply down to earth. Look for a wiring fault around there.
