Author Topic: My 750 f coming together  (Read 1276 times)
Offline fireman1073
« on: December 11, 2019, 10:30:42 AM »
Offline remcoseegers
Re: My 750 f coming together
« Reply #1 on: December 11, 2019, 10:35:36 AM »
Looks great!
« Reply #2 on: December 11, 2019, 11:43:28 AM »
Great start. If you need any parts I may have you covered.
Offline kerryb
  • Not a very
« Reply #3 on: December 11, 2019, 02:11:17 PM »
Looking great, keep up the progress.
Offline maxheadflow
« Reply #4 on: December 12, 2019, 07:17:55 AM »
Looks good but you might have issues assembling the fork trees / tubes as it looks like the insides of the fork and stem clamps are powder coated.  The PC can be 10 to 20 thou thick easy. One thing to note on the timken's is that if you don't use a lower spacer under the bearing, the neck might rub the lower tree. I didn't use one on my 78K 750 and had to clearance the  lower tree to keep the 2 from rubbing. I only painted the lower tree so it wasn't much of a problem touching up.
« Reply #5 on: December 12, 2019, 06:26:44 PM »
Powder coat is normally only .002-.003 thick...
Offline maxheadflow
« Reply #6 on: December 13, 2019, 07:24:32 AM »
Not where a I get it from.   I generally machine the stuff off on things like forks. It might be as thin as 0.003" on corners but the stuff I've seen is pretty thick on the flats. Touch the tool on the PC and it don't clean up until 0.010 to 0.020 later.  Even if its 0.003" thick it means the gaps on the pinch areas will increase by over 0.009"  If using top pinch washer forks, you'll have problems.
Offline fireman1073
« Reply #7 on: December 14, 2019, 10:24:00 AM »
good catch but i already removed the coating in them areas
Offline maxheadflow
« Reply #8 on: December 14, 2019, 01:07:20 PM »
Since PC can be a PITA to remove, how did you remove it?
Offline fireman1073
« Reply #9 on: December 15, 2019, 07:27:33 AM »
just sandpaper thing in a drill you know the round flap thing
Offline pjlogue
« Reply #10 on: December 15, 2019, 09:49:47 AM »
Something very gratifying about bolting nice clean shiny things back on the bike.  Your engine looks new as well as all the parts.  NICE JOB!
-P.
Offline maxheadflow
« Reply #11 on: December 15, 2019, 12:35:15 PM »
Know it well.  Thanks for the reply.
Offline desertrefugee
  • Still wanna be a...
  • Phoenix, AZ
« Reply #12 on: December 17, 2019, 07:46:38 PM »
That is really looking good.  Makes me look at my '78F and realize just how far I have to go...
Great work.
'86 Vmax, '83 ZN1300, '78 GL1000, '75 CB750 K5, '78 F4
