Author Topic: SOHC 750 Trike  (Read 436 times)
Offline Old Moe Toe
SOHC 750 Trike
« on: December 22, 2019, 11:47:29 PM »
Saw these pictures out there in cyberland and thought they may be of interest.
Does it go?
I don't know.
Maybe there is a fuel and oil tank hidden in there somewhere.
Offline b1jackson
Re: SOHC 750 Trike
« Reply #1 on: December 23, 2019, 01:37:19 AM »
I'm not sure about fuel but for oil, there appears to be a larger cannister on the front of the engine where the filter mounts. Maybe fuel is carried in back pack?  ;D
Old Honda Rescue Centre
ohrc_vintagemoto on Instagram
Offline kerryb
  • Not a very
Re: SOHC 750 Trike
« Reply #2 on: December 23, 2019, 05:00:08 AM »
 Is that an Isetta it is parked next to?  Boy it sure is small.  I guess if someone wanted to make an extreme "big wheel", they hit the mark pretty well.  Just not sure that much effort is worth a 5 minute ride.
Re: SOHC 750 Trike
« Reply #3 on: December 23, 2019, 05:35:50 AM »
I have seen it before but can't really tell, backpack fuel would be a great idea. I suppose you could run a short while if you had even a quart more oil than what is always in the engine., or maybe he just stores it in the cases, and it works like when our pumps leak.
 A few more pics would help, but I have only ever seen a few views, need to see oil line area and rear axle. I suspect it has a rear disc,  as there is a master cylinder in board of the left footpeg. I am thinking if it gets ridden its probably only in one or two gears
