Author Topic: Plating pistons to save a bore job.  (Read 2691 times)
« on: December 23, 2019, 11:40:20 AM »
There us a process I heard of on CycleDrag,  U.S. Coatings is the name of the place, they have 4 facilities in the USA. They claim good results on I think pro mod cars.
 They build up the piston up to several thousands with a good coating process, then you hone your bores and refit them. 36 bucks per piston.
 Anyone tried this. I wonder if they mask ring grooves and pins. They also do top coatings.
 Pretty interesting.
« Last Edit: December 23, 2019, 12:09:51 PM by 754 »
Re: Plating pistons to save a bore job.
« Reply #1 on: December 23, 2019, 12:43:39 PM »
Sorry, I meant this for Hi Performance section..
Offline KayOne
« Reply #2 on: December 23, 2019, 01:44:34 PM »
Hi Frank, I’ve had Piston skirts from my SBF coated to get more life out of the bore and piston. Works very well. A supposed benefit is less piston drag and wear on the bore. I’ve also thermal coated the top of the pistons but truly can’t say if there is any benefit. Yes they do mask off the lands somehow. There is a good coating shop in Calgary, couriered my pistons there and had them back the next week.
CB750 K1 restored
1979 CB750Fz - original except for exhaust, 14000km
1984 VF45F Interceptor - all original, 12000 km
1968 S90 - all original, 2100 miles
1973 H2a, Restored
1973 H1D, next project
CB750K1 (sold)
1976 KZ900 (sold)
1981 CB900F (under restoration)
2015 Yamaha FJ09, my appliance rider
Offline gschuld
« Reply #3 on: December 30, 2019, 06:47:34 PM »
Swaintech does a PC9 skirt coating.  They can go thicker if desired.  Mike Rieck has used them with success for the same purposes you are asking about.
George
« Reply #4 on: December 30, 2019, 07:00:31 PM »
Thanks for the info, nice to know we have one that close.  I probably have a few bigbires I can bring back for cheap.
« Reply #5 on: January 03, 2020, 10:18:44 PM »
How much will the coating build up?
Total bore/ piston clearance.
Offline gtmdriver
« Reply #6 on: January 04, 2020, 01:45:22 AM »
I wouldn't think that the process would be successful if there was any ovality in the bores though.
« Reply #7 on: January 04, 2020, 08:22:49 AM »
Bores can be honed to correct shape which will need thicker pistons were a coating can do it right.
I guess this is rhe way this is done, right?
« Reply #8 on: January 04, 2020, 09:53:50 AM »
I am thinking they go a bit oversize,  then you hone and fit to piston.
« Reply #9 on: January 04, 2020, 12:03:22 PM »
I have heard about pressing a forged piston over the wrist pin sides and let it swell so the skirts fill the bore better. A friend of mine heard that from an experienced mechanic as the last trick to get more life out from the pistons and their bores.
My friend had a cylinder where one of the forged pistons had sloppier fitment. Piston into a vice and press some. That helped!
He had a wristpin in just for sure to ensure how the piston change when deforming it.
« Last Edit: January 08, 2020, 10:33:39 AM by PeWe »
Offline wwsummersjr
« Reply #10 on: January 04, 2020, 03:20:25 PM »
What about ring gaps after honing cylinders to fit piston skirts?
Offline Steve_K
« Reply #11 on: January 04, 2020, 04:15:34 PM »
When I was working in a bike shop, the shop owner knurled the pistons for a British twin.  The bike owner did not have the cash for a full rebuild, so the owner did that.  Back then, I think a rebuild cost $700 to $800 for that.   Remember, Brit bikes needed to be rebuilt after 10.000 miles.
I don't know how well I worked, but the shop owner was a very good tuner for BSA twins for dirt track.
Steve
Steve_K
« Reply #13 on: January 05, 2020, 02:50:20 AM »
I bought an antique piston knurler on Ebay many years ago, my cousin (vintage car and bike mechanic) told me all about it, it was a common procedure back in the Great Depression, when people had no money for rebuilds. I actually tried it on some CB750 836cc pistons to get rid of a "piston slap" issue using a standard knurling tool in my lathe, and it worked fine. ;D
« Reply #14 on: January 05, 2020, 04:40:21 AM »
More piston coating
https://www.line2linecoatings.com/slickCC.html
They have several products for pistons
It would be nice with a product that can be applied on pistons and baked in oven when wife is away :)
My oven can be set to max 300°C  (570°F ).
« Reply #15 on: January 06, 2020, 07:32:16 AM »
I have not heard that so I searched.  There are som pics of knurled pistons.
https://www.google.com/search?q=knurled+piston&client=ms-unknown&prmd=isvn&sxsrf=ACYBGNT1aYiBwtiTVo8ovWM-xJ3TSdfdLw:1578204562264&source=lnms&tbm=isch&sa=X&ved=2ahUKEwjGy8OS5uvmAhXKo4sKHfpBCTsQ_AUoAXoECA0QAQ&biw=355&bih=620
If the piston taper has been worn out I can't see how knurling would bring it back. I can see it expanding the OD a bit but not reestablishing taper.
« Reply #16 on: January 06, 2020, 11:47:02 AM »
New for me,  seems to  have been done for years.
It might reduce rattling pistons due to skirt bore clearance.
« Last Edit: January 06, 2020, 12:19:45 PM by PeWe »
« Reply #17 on: January 08, 2020, 02:37:23 AM »
Exactly, it wasn't a permanent fix, it was just done to get a few more miles out of a tired engine. Expanding pistons, on the other hand was a common fix for 2 strokes that would regularly "nip up" if the ridden mercilessly, or with poor quality 2 stroke oil. ;D
« Reply #18 on: January 08, 2020, 10:15:37 AM »
Another coating provider
https://techlinecoatings.com/tech-line-coatings/hi-performance-coatings/internal-engine-coatings/
This might be something for sloppy bores.
TLMB POLYPHEN BASE BUILD-UP COATING
High load durable thin film lubricant.
Primarily used to build up piston skirts.
Used in very high RPM engines or where very long rods are run.
Top coat with either TLML or PKSX.
Solvent based, cleanup with Acetone or similar.
Requires oven curing at 300°F for 1 hour.
Part #TLMB available in Quart & Gallon. For professional applicators only.
I have not verified "professional applicators".
Spray gear or workshop?
Would be perfect if available on rattle cans.
The juicy ribs will taste different  shortly after a piston job ;)
Extra spicy rub needed....
Women in general do not like engine parts in oven. :)
New roller bearing in the freezer OK.
Offline johno
« Reply #19 on: January 09, 2020, 10:03:50 PM »
Like your style and Love your humour PeWe ;D ;D ;D
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
