Author Topic: Brake light switch wiring for front brake  (Read 742 times)
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« on: January 09, 2020, 05:06:48 PM »
Can anyone post a photo example of how that should look? Mine works but it's sort of messy coming off the main loom. Any suggestions as far as wrapping beside electrical tape?  Thanks.
Sent from my LG-H871 using Tapatalk
cb750 k6 - ugly
Re: Brake light switch wiring for front brake
« Reply #1 on: January 09, 2020, 11:22:52 PM »
There should be 2 wires, mostly coverd in a plasic sleeve that connect to the hydraulic switch
Offline evinrude7
  • not a kung-fu
« Reply #2 on: January 10, 2020, 06:33:54 AM »
plastic sleeve... thanks.  can't seem to find a part # for the sleeve.
« Last Edit: January 10, 2020, 06:39:44 AM by evinrude7 »
cb750 k6 - ugly
« Reply #3 on: January 10, 2020, 08:29:34 AM »
There iisnt one its fitted when the loom is new
« Reply #4 on: January 10, 2020, 11:00:13 AM »
On a 500 its a seperate sub loom 35345-319-000
Offline evinrude7
  • not a kung-fu
« Reply #5 on: January 10, 2020, 04:19:51 PM »
got it.  i can probably use some heat shrink tubing. trying to tidy that area up.  thanks for the insight.
cb750 k6 - ugly
« Reply #6 on: January 10, 2020, 05:01:09 PM »
vintage fasteners used to sell sleeve material. Or, if you're not going for concours original shrink tubing.
Offline evinrude7
  • not a kung-fu
« Reply #7 on: January 11, 2020, 05:29:44 AM »
thanks don.  originally when bryan mentioned a sleeve i was imagining a rubber sleeve that also covered the hydraulic switch (sort of like the one at the banjo bolt up by the front brake res) but i see from the cb500 part pic that it's just over the wires.  no concours original here so heat shrink will do the trick.
cb750 k6 - ugly
Offline pjlogue
« Reply #8 on: January 11, 2020, 06:22:00 AM »
If you go with heat shrink, put ~1" on each wire at the bullet for support and then leave a good amount of wire exposed before having heat shrink cover both wires back to the harness.  There is a lot of flex in the wires with the head and if you run the heat shrink up close to the bullet connectors, the flex will focus on the wire at the connector and break eventually.
-P.
Offline evinrude7
  • not a kung-fu
« Reply #9 on: January 11, 2020, 07:03:39 AM »
-P.
Good point.
cb750 k6 - ugly
Offline evinrude7
  • not a kung-fu
« Reply #10 on: January 12, 2020, 12:53:35 PM »
looks a bit better now and have to be more solid connections.
the yellow wiring and #$%* bullet connectors are what were on there before.
« Last Edit: January 12, 2020, 02:53:31 PM by evinrude7 »
cb750 k6 - ugly
