Author Topic: cb750 k2 alternator wiring harness routing?  (Read 1364 times)
Offline CaptFatCat
« on: January 13, 2020, 05:11:28 am »
I cannot figure out the proper way to route the wiring harness from the alternator with the 3 yellow bullet connectors, oil light and neutral switch thru the counter sprocket cover and shift cover. are the bullet connectors exposed under the sprocket cover?
will someone post a pic for me?
Thanks
Resurrecting a Herman Munster CB750 from a few old baskets of K2 and K7 parts.
Offline 69cb750
Re: cb750 k2 alternator wiring harness routing?
« Reply #1 on: January 13, 2020, 05:25:36 am »
Wires route through crankcase slot on left then turn in between case and lip on sprocket cover.
« Reply #2 on: January 13, 2020, 07:51:10 am »
Pics from my K2 build.
3 yellow alternator wires + 2 wires for field coil sitting in the cover meet the upper harness with neutral switch wire to rectifier inside the shift cover/sprocket cover. You'll see when alternator cover goes on. Do not forget the rubber these wires goes thru on alternator cover. There is a bracket there too.
Oil pressure sensor wire with starter motor cable.
« Last Edit: January 13, 2020, 07:56:39 am by PeWe »
CB750 K6-76 1005cc JMR Billet block.
Offline CaptFatCat
« Reply #3 on: January 13, 2020, 02:57:25 pm »
Thanks PeWe.
The pics are great.
I was lost on where to tuck the bullet connectors under the sprocket cover.
It didnt seem right having them located where the chain can sling grease on it. I see they can be tucked away and strapped with the keeper on the case.
Offline CaptFatCat
« Reply #4 on: January 13, 2020, 08:33:51 pm »
P.S.
That is a Fine looking motor PeWe!
