Author Topic: metric tubeless on Comstar in inches  (Read 1831 times)
Offline ORAZIO
« on: January 13, 2020, 01:21:28 PM »
Hello
on my 1978 Hondina I have to change tires.
I found on the market a 110/90/19 front and a 130/90/17 rear.
The question is, can I avoid putting the inner tubes and using these tubeless tires on comstar wheels?
Orazio
Offline dave the welder
  • dave the welder
Re: metric tubeless on Comstar in inches
« Reply #1 on: January 13, 2020, 02:13:42 PM »
my guess would be no. just put tubes in and ride
don't buy it build it
Offline jukku
  • Happy with my Hondamatic
« Reply #2 on: January 13, 2020, 11:12:07 PM »
I use the Comstars with tubeless 100/90-19 and 130/90-17 on my ToMatic, without any problems.
Offline ORAZIO
« Reply #3 on: January 14, 2020, 01:05:52 PM »
Well Jukku
I was what I wanted to know, my trusted tire dealer has no experience on these Comstars and I preferred to ask you more experts.
Do you know if there are problems with the assembly of automotive valves?
Thanks to those who express themselves through their experiences.
Orazio
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: January 14, 2020, 02:25:27 PM »
I’ve used tubeless tires on Comstars and my Lester wheels too. For valve stems I used a competition style bolt-in unit. They are externally threaded, use a rubber gasket top and bottom, and fastened with a top nut. From memory, I may have had to open up the hole size a bit, but they worked really well.
Offline jukku
« Reply #5 on: January 15, 2020, 01:21:40 AM »
I use bolt-in 90 degrees valves on the rear wheel because it is easier to check the pressure.
Offline ORAZIO
« Reply #6 on: January 15, 2020, 01:19:41 PM »
Thank you
I think I can do as you recommended with the bolted valves too.
 good way to you all
Orazio
