Author Topic: CB400/4  (Read 704 times)
Offline allankelly1
CB400/4
« on: January 18, 2020, 12:58:51 PM »
Evening all
New member here
Always has a soft spot for the CB400/4
And after a chat with the darling wife I am now a proud owner of a red 1977 bike.
The bike itself is reasonably tidy and is running ok and even came when I opened up the seat the original tool kit and a 43 year old owner’s manual
The bike could do wilt  a bit of work here and there and first thoughts were to restore it to an original bike, but to be honest I thought the same when I got a RD350LC “project bike” for the Yellow RD350LC project but to be honest like to have something that is in keeping with the period but also has a few personal unique touches / changes
Took it out for a quick ride today and the front brake is totally carp and is In dire need of either repair of replacement so first change will be to look at the possibility to replace the complete front disc brake with a more modern  single piston floating calliper twin disc set up off a bike from the mid 80s just to keep the period look
Once this is done and she has had a good check over (and a mot just to tick the box for insurance proposes as it’s not been for a mot since 2012) then I will use her for the summer in its current state while getting other goodies such as a Yoshi cyclone exhaust, ally rims and stainless spoke kit electronic ignition and a few other bits and bobs in preparation for the end of summer where it will be time for a complete strip and rebuild from the ground up just like the RD
In the meantime will keep you all up to date on how goes including the front disc upgrade
Best wishes Al
« Last Edit: January 18, 2020, 01:01:24 PM by allankelly1 »
Offline tool14
Re: CB400/4
« Reply #1 on: January 18, 2020, 01:10:02 PM »
welcome aboard.
Offline Can550
Re: CB400/4
« Reply #2 on: January 18, 2020, 07:47:05 PM »
Welcome from cold Canada
Great 400f
Offline carnivorous chicken
Re: CB400/4
« Reply #3 on: January 19, 2020, 10:17:18 AM »
Clean 400!
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
Re: CB400/4
« Reply #4 on: January 19, 2020, 03:35:48 PM »
Welcome from Lake Superior,
Nice find,
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
Offline allankelly1
CB400/4
« Reply #5 on: January 22, 2020, 01:12:20 PM »
Hi all
Thanks for the hellos
Well decided to take the plunge and convert the CB 400/4 to a twin disc front end
I know it’s not original but really like the symmetry of a twin disc front end and bike was alway going to be slightly different from original anyway
There’s a bit of way to go yet as to get the correct fork length the fork assemblies are 400/4 stanchions / damper assemblies with CB400N lower sliders that will need the lower section of the stanchions modifying to incorporate the later Honda design that has a spilt bush on the bottom of the stanchion that runs in the slider bore rather than the complete stanchion leg
Also hub and discs will need some changes as original disc is a four bolt mounting and the donor discs are five
(And the plain discs will be drilled at some point too)
Lastly due to the extra disc the speedo drive willl need a tweaking to get the drive past the extra disc,
But none of the above are impossible to solve and I have alway enjoyed the challenge of solving problems )Also having access to a full tool room helps ) Plus the bike it will stop much better than the original pivot design
Catch up with you all soon
Best wishes Al
