Author Topic: rattle can paint  (Read 1629 times)
BruceA cb550
rattle can paint
« on: February 06, 2007, 11:39:48 AM »
Did some experimenting with Dupli-Color Mirage paint, its the spray can version of chameleon paint.  Comes in a 3 step set, base coat, color coat, and clearcoat.  With some good prep and some1200 grit wet sand every other coat, this is going to workout real nice.  I'll have the tank and side covers done for less than $50.  I'll post some pics when I get everything back on the Bike and have decent weather to get outside for photos.
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
Re: rattle can paint
« Reply #1 on: February 06, 2007, 12:14:47 PM »
Rattlecan paintjobs can turn out good, as long as wetsanding is done...
Offline ElCheapo
    • Anubis Cycle
« Reply #2 on: February 06, 2007, 12:21:42 PM »
My bikes are proof of that.  ;D
Contact me for affordable rotor drilling services at $55 each rotor. Same day service on CB750/CB500/CB550 rotors. Next day on everything else.
Offline Steve F
« Reply #3 on: February 06, 2007, 12:56:07 PM »
Just don't get any fuel on it.
Offline ElCheapo
    • Anubis Cycle
« Reply #4 on: February 06, 2007, 01:11:17 PM »
Dont matter  8)
I have spilled fuel on Home Wrecker lacquer paint job a few times. No effect.
You have to pick your paint correctly.
Offline ProTeal55
  • Est1968.com
« Reply #5 on: February 06, 2007, 01:15:02 PM »
When I was running the low-gloss engine enamel paintjob on the CB750, I spilled fuel on it a few times. My fix to that was a total tank re-spray while it was on the bike. I actually got pretty good at it (i must admit). All I did was take a extra large bedsheet, throw it over the bike, and then cut a slit just big enough for the tank to "pop out". This allowed me to paint the tank on the bike, and not get overspray on everything..
 ;D
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #6 on: February 06, 2007, 01:35:57 PM »
You guys are all way too talented. My botched rattle can attempts have been a total embarrasment.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline ElCheapo
    • Anubis Cycle
« Reply #7 on: February 06, 2007, 01:37:55 PM »
 ;D
Slick Idea  ;)
Offline ProTeal55
  • Est1968.com
« Reply #8 on: February 06, 2007, 01:58:43 PM »
Allot of it has to do with the prep.
I went thru about 2 cans of sandable primer before I shot the final "coat" of paint on this..
This was Ace Hardware brand low gloss high heat paint..
It is always easier to make a rattlecan job look good if you are doing flat/semi-gloss rather than a gloss job.. ;D
Plus - you could always take your time and do a good rattle can job, then take it to a bodyshop and throw them $20 to clear over it. Would save the paint from the random fuel spilling..
« Last Edit: February 06, 2007, 03:22:08 PM by ProTeal55 »
Offline ElCheapo
    • Anubis Cycle
« Reply #9 on: February 06, 2007, 05:32:51 PM »
I agree with you Teal on the prep work part.......
Most body shops will not clear over because of incompatibility between paints.
I have never had a problem with the paint issue.
Solid color coverage, then SICKO clear coat (10 coats) and keep buffing.
Looks like glass when you are done.  ;D
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #10 on: February 06, 2007, 07:43:09 PM »
Woah, I'm so used to seeing that bike with the Linex'd tank 8) that I'd forgotten it used to have a 'normal' one ::)  It just looks wrong that way now ;)
1978 CB550 K3
1985 H100S
Offline turtle
  • 1980 CX500 Custom
« Reply #11 on: February 06, 2007, 10:38:44 PM »
I agree with you guys. There is rattle can paint and rattle can paint. Mostly, you get what you pay for and as has been said, it is all in the preparation and finishing. There is a guy here is Oz who has developed candy paints (3 part system) high quality acrylic lacquer. I can't wait to try them. Unfortunately he can't / won't post overseas because of carriage of danger ous goods.
1972 CB350 Four
1977 CB750 K7
1979 Suzuki GT250 X7
1980 CX500 Custom
1980 CX500 Shadow
1981 CB900 Bol D'or
1982 CB750 F2
"If it ain't broke, don't fix it."
Serenity
« Reply #12 on: February 07, 2007, 12:15:14 AM »
Proteal that bike is way cool...had to keep coming back to check it out
Offline turtle
  • 1980 CX500 Custom
« Reply #13 on: February 07, 2007, 01:52:27 AM »
Bike looks great Proteal. We have found that high heat paints (engine enamel) is only good where the temperature gets really hot (ie on the head and block). Other areas (even the crank case) donn't get hot enough to bake the paint, and it never really hardens properly. We usually use wheel enamel sillver on crankcases etc. (Septone from Supercheap Autos is good, also White Knight from Bunnings.)
1972 CB350 Four
1977 CB750 K7
1980 CX500 Custom
1980 CX500 Shadow
1981 CB900 Bol D'or
1982 CB750 F2
